Thread: Temp not hitting 90
  1. Temp not hitting 90
    Jan 2009
    Birmingham
    36 Post(s)
    Hi had my cambelt water pump and stat changed by the dealers about 3 months ago problem is temp on dash does not hit 90 always just under drive it hard can get to 90 bit then falls back just under could it be the stat stuck open changed the temp sensor for a genuine green one before the dealer did the work so can a state go bad that quick
  2. Re: Temp not hitting 90
    Mar 2007
    10 Post(s)
    yes mate stats can go bad at any time i have had them straight out of the box stuck open . does the car take forever to reach just under 90c if so then your stat is stuck open . one more thing to keep in mind is that it as been a bit cooler as of late this will have an effect on your warming up time . but you should still get to 90c and stay there as long as you have not got your heater on full flow and at high temp just remember there is no given time for any new part to fail
  3. Re: Temp not hitting 90
    Jan 2009
    Birmingham
    36 Post(s)
    Quote Originally Posted by sbt View Post
    It does get to 90 but does not stay ther it falls just under 90 few mm under 90 I have the ac on all the time but if I switch it off it goes to 90 quicker even taking sharp corners affect it say if it bang on 90 take a sharp corner and it just goes couple if mm under another thing is my mpg all I drive is local start stop no a roads or any longish stretch of road put in a full tank and I get just over 400 miles off it full tank last me about month and half all my journey are short school, work are 10 minutes away anyway thank for your reply oh yeh forgot to say car is a audi a4 1.9 tdi 115 sport 2004 BKE
  4. Re: Temp not hitting 90
    Mar 2007
    10 Post(s)
    it does not sound like there is anything wrong with your car its all the short trips the engine is not getting properly hot regardless of what your temp gauge says . i have got a 2004 1.9 tdi 130 bhp i can fly down the motorway with it up to 90c but if i stop in traffic the temp goes down slightly especialy in the colder months . its all to do with diesel being far more thermally efficient than petrol engines . when it is realy cold like last winter it used to take my car about 5 or 6 miles on the motorway to get fully warm
    May 2008
    Once you're warmed up it should stay at 90. All the 10+ VAG cars I have owned have never fluctuated from 90 regardless of driving conditions.
  6. Re: Temp not hitting 90
    Aug 2007
    Newport, Wales
    7 Post(s)
    I suffered with a temp guage that hovered between 50c - 90c for about 2 years!
    To start off with I changed the temperature coolant sensor.. no joy. I then did some digging on this forum to find people suggesting changing the thermostat.
    I changed the thermostat and my car now hits 90c and stays there no matter what kind of driving I'm doing. I'll bet it's that!
    Here's a guide on how to do it on a 1.8T but the process is just the same for the 1.9 TDI (the thermostat is located just below the alternator).
    http://forums.vwvortex.com/showthread.php?1730221
    it's about a 1.5 hour job start at finish at my amateur level! That's dicounting the hour I spent trying to recover the bolt I dropped from the thermostat housing
    Toff.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  1. Please Help no power steering after hitting a cateye
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-07-2011, 07:27 PM
  2. Vibration after 40mph after hitting kerb
    By boycey19690 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-01-2011, 10:02 PM
  3. Question knee hitting steering column
    By ted99 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-11-2010, 09:58 AM
  4. Please Help temp hitting the red
    By 786sam in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-04-2010, 04:18 AM
  5. Steering light after hitting kerb
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2007, 07:11 PM
