Thread: Bigger discs = better brakes ?
Hybrid View
  1. Bigger discs = better brakes ?
    Dec 2006
    Evening everyone advice please.
    I need to replace the discs and pads on our Discovery 3. I have heard that I can replace the xisting disc with one of a larger diameter. I have been told that this will offer increased breaking capabilty. What I can't understand is how this would be. If the caliper is of the same size and the disc diameter only is changed how is the breaking power is increased?
    Any help much appreciated.
    Cheers,
    Duncan
  2. Re: Bigger discs = better brakes ?
    Oct 2005
    Lutterworth
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Re: Bigger discs = better brakes ?
    Apr 2007
    Lancashire
    Bigger discs normally require bigger calipers, with more friction from larger pads.(or pads mounted further from hub)
  4. Re: Bigger discs = better brakes ?
    Coventry
    I'd agree that bigger disks will require bigger calipers as the circumference will have changed. Either way, the brakes, however big, are only as good whilst the tyres maintain their adhesion with the road surface. If they lose it, then you might as not have them.
  1. A bigger octavia?
    By Ben in forum Superb
    Last Post: 17-07-2008, 10:49 PM
  2. Bigger injectors - TDI
    By releaseyourself in forum Archive posts
    Last Post: 07-07-2007, 07:23 PM
  3. front brakes and discs
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 04-07-2007, 09:11 PM
  4. bigger injectors
    By quattro79 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2007, 12:14 PM
  5. Bigger Petrol Tank?
    By logdrop in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-01-2007, 01:53 PM
