Thread: Adjusting CC window
  1. Adjusting CC window
    Dec 2010
    Leics
    Hi all,
    I am experiencing quite a bit of wind noise from the passenger window at motorway speeds. I am 99% convinced it's because the window needs to go bait higher.
    Is it simple to do this. Looking on the Internet it seems the two covered bolt holes under the door do it. However I have removed the covers and can't quite work out what to do. Do I undo both and lift window then tighten?
    Any help is much appreciated.
    Tremly
    Ps it is still under warranty but if it's simple I would prefer to do it.
  2. Re: Adjusting CC window
    ibbotsonf Guest
    Would suggest you get your dealer to see if one of the internal seals in the door is misaligned. I had this problem with the drivers side. Dealer spent ages trying to work out what the problem was but eventually realised the noise came from air entering the door at the bottom through the drain holes, flowing up through the inside of the door past the misaligned seal and exiting at the window.
  1. Adjusting rear wipers on a T5
    By Suggsie in forum The Commercial Range
    Last Post: 10-10-2011, 04:07 PM
  2. Rear brakes adjusting
    By 1198polo in forum Polo - Derby - Lupo - Fox
    Last Post: 23-01-2010, 08:01 PM
  3. self adjusting clutch cable
    By sam cockerill in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2009, 09:33 PM
  4. Adjusting Headlights from UK to Europe
    By lee9367 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 07-02-2009, 12:00 PM
  5. Adjusting Drivers Door
    By mateus77 in forum Golf MK5 - 2004 - 2009
    Last Post: 22-06-2008, 05:34 PM
