Thread: Key Fob Spring
  1. Key Fob Spring
    A3 Sportback Guest
    The flip out key spring has failed.
    Can the spring be obtained/replaced?
    Any help appreciated, thanks.
  2. Re: Key Fob Spring
    Oct 2011
    Aylesbury
    Hello.
    I haven't seen the springs sold seperately but you can buy the entire casing for around £10-£20 on eBay. You could get one of these and switch your blade/circuit board/transponder over into it. A search for 'Audi flip key' or similar will bring them up, just ensure you get the right one as there seems to be variation in the battery holders.
  3. Re: Key Fob Spring
    Jan 2010
    Wakefield, West Yorkshire
    Just buy the correct shaped key as Sk1ppy says and swap the spring over. You don't need to touch the keyboard/circuit board/transponder as the key blade and spring are completely separate.
  1. resync key fob problem only one key...
    By rustictwist in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2011, 08:11 AM
  2. Replace spring in flip key
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 12-05-2010, 09:27 AM
  3. I need a new key fob
    By phoenix9705 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2008, 07:33 PM
  4. 1999 new Beetle US Key and key fob
    By dewman in forum Beetle 2000-
    Last Post: 29-01-2008, 09:42 PM
  5. Key fob battery and Key cut
    By richjthorpe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-04-2007, 07:43 PM
