Thread: Key fob not working after replacing battery
  1. Question Key fob not working after replacing battery
    Oct 2011
    Leeds, United Kingdom
    My key fob for the central locking does not lock or unlock the doors or boot or seemingly do anything. It became gradually weaker so I replaced the batteries but no luck. I'm having to unlock the passenger door manually then put the key in the ignition to turn the alarm off.
    Before I ring the garage, is there anything simple I'm missing?
    W plate, 2000, Golf Gti 2.0
  2. Re: Key fob not working after replacing battery
    Jul 2007
    does the little red diode bulb on the keyfob come on when press the lock/unlock button on the fob?.
    if it does't the the keyfob battery is faulty..
    if it does,then you will need to synch. your keyfob to the car,the instructions on how to do this are is the owners manual if you got one.
  3. Re: Key fob not working after replacing battery
    Oct 2011
    Thanks for the reply SPS. My keyfob doesn't have an LED.
    I'll get it to the garage but just busy with other stuff at the moment. :-)
  4. Re: Key fob not working after replacing battery
    Aug 2008
    Wigan
    9 Post(s)
    The key should operate both the lock and the alarm. If you have central locking, the locks should all open and close when you open and close the driver's door lock. If these aren't working you may have a problem with the electrical connections on the door lock. Look here - http://forums.vwvortex.com/zerothread?id=1542461 for more information on the locks. There are posts on this forum which should explain how to re-sync the keyfob and the car's lock system, better than the manual.
  1. Key fob battery?
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-10-2014, 09:40 PM
  2. Replacing remote key fob batteries!
    By Andy_GolfTDI in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-04-2011, 09:31 AM
  3. Key fob battery
    By dib in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2010, 05:05 PM
  4. replacing battery in key fob
    By dancerdave in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 10:51 PM
  5. Key fob battery and Key cut
    By richjthorpe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-04-2007, 07:43 PM
