Thread: Cabrio brake warning light
  1. Cabrio brake warning light
    Aberdeen
    Hi I have a problem with my cabrio 2.6, I have a problem that the brake warning light keeps coming on I have checked the fluid this is ok, changed the discs and pads so this isnt an issue this leads me to believe that it is an ABS sensor, is there a way to check to find which one is the problem myself? Thanks
  2. Re: Cabrio brake warning light
    a fault code read will show what is wrong
  3. Re: Cabrio brake warning light
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    If you have recently changed discs/pads, have you knocked the ABS sensor? Maybe a look/clean/reposition would cure it, but as kenney says a code read will certainly point in the right direction
  4. Re: Cabrio brake warning light
    Aberdeen
    Hi I got the problem fixed now thanks for the ideas.
  1. ABS warning light & flashing brake light
    By mrbiondi in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2011, 01:47 PM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  4. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
