Thread: Emmisions Control System
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Emmisions Control System
    Jul 2008
    Hello,
    This morning the emmisions control system light came on my vehicle. It is a Apr/May 2008 A6 2.7 Le Mans edition and I was just wondering if these vehicles have a DPF fitted? If I accelerate hard I can usually see some smoke behind me. I'm really hoping that this is not serious or expensive to fix. I've read it could be something as simple as a sensor which is about £100 max.
    P.S - its done 58,500 miles
    Any ideas?
    Thanks!
  2. Re: Emmisions Control System
    Jan 2010
    Chobham, Surrey
    The light 'just' means there is a persistent engine fault. You should get the codes read to find out what it actually is.
    Mine is lit because of the swirl valve linkages. These can only be obtained as part of new inlet manifolds and at £2K they are staying unfixed. Hopefully yours is something cheaper.
    Golf GT 140 TDI. Mods: RNS510
  3. Re: Emmisions Control System
    Jul 2008
    What are your symptoms?
  4. Re: Emmisions Control System
    Jan 2010
    Chobham, Surrey
    There are no symptoms I can detect. Fuel economy seems unaffected on longer journeys, but might be marginally worse on short ones.
    But you need to get your codes read as it could be anything (well, any of a number of things).
  5. Re: Emmisions Control System
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Just another possibility, my problem started after around 60-65k on the clock - emmissions light came on, heavy black smoke out of the rear & intermittently the turbo would fail to kick in (the turbo problem would go away at first when I stopped & restarted the engine). As you've not mentioned your car losing power I hope your problem isn't the same as mine, but mine was due to a split in the intercooler.
    When I had this problem & asked for help on here, people were suggesting that based on my symptoms I should also check the all the pipes and the MAF meter, so it may be worth checking those.
    Hope your problem is simple & cheap to fix.
    Cheers,
    Paul.
    The Only Way Is A6!
  6. Re: Emmisions Control System
    Jun 2011
    Worcester
    have you any loss of power?
    Take the Engine plastic cover off (just pull .. only clipped on) and check your rubber hoses to and from the EGR valve - check for splits!
    Then do the same for the turbo, take the intake hose off and look at the fly wheel on the turbo - any oil
    But as the rest of the chaps say, it needs the code read to be sure.
  7. Re: Emmisions Control System
    Feb 2009
    My EGR sensor failed 2 weeks ago on my 2010 2.0tdi, luckily still under warranty. There was no idication of a problem other than the engine fault light came on, called out Audi roadside and the guy says its a common fault and the new sensor is an upgrade. Seems to be an issue caused by the AC unit?????
  8. Re: Emmisions Control System
    Jul 2008
    I will do the checks in the morning. And no I've not noticed any loss in power. It still pulls like a train and is smooth throughout the power. Where abouts is the EGR valve located?
    Thanks.
  9. Re: Emmisions Control System
    Jun 2011
    Worcester
    It's just to the left of the passenger side bank, silver module - lines feed to and from - the from goes to a intercooler I believe.
    Sorry hard to explain, others might explain better - I'll take a pic and post it from my 3.0dti - same layout I believe if you cannot locate it.
    But as you have no loss of power, it's not going to be this - mine when into limp mode (trip gear box - 40mph max) until EGR was replaced £300 - then hose went after £20 (free from Audi - as they broke it swapping the valve)
    Regards - rob
    Last edited by Dpanic; 14-10-2011 at 10:11 PM. Reason: Remove pic Link , messed it up sorry
  10. Re: Emmisions Control System
    Jul 2008
    Right. Took it out with a lead foot and my god it has lost some power. I can't believe it. It's only been the missus that has been driving it the past few weeks and I doubt she noticed. (im on a manual) and the engine does sound a bit louder overall I am really praying now that its not the turbo. Can an EGR be replaced by your average joe?
  1. Emissions control system
    By adam_gold in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2011, 07:55 PM
  2. Voice Control System not working
    By shahid8850 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-03-2010, 11:24 AM
  3. emmsion control system
    By the-stigg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-10-2009, 10:43 PM
  4. Voice Control System
    By JFLETCHRM in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-08-2009, 03:11 PM
  5. Emission control system on Ibiza
    By Seshat in forum Ibiza - Cordoba
    Last Post: 23-03-2008, 01:44 PM
