Thread: Water Temperature Indicator
  1. Water Temperature Indicator
    Dublin, Ireland
    I have a 2002 Golf, 1.6 Litre, petorl .
    As most of you know, the temperature indicator on the display for the water can go between 0 and 130 degrees with 90 degrees being the temp right in the middle there the temperature indicator should be resting
    I have noticed 2 things when driving lately
    1 ) It can take 15 minutes for the indicator to get to 90 degrees and it sort of jumps all of a sudden from 0 on the indicator to 90. Is this any harm ??
    2 ) I noticed when driving and the water temperature indicator has reached 90 for a while, that sometimes, it will suddenly drop to 30 degrees and then right up to 90 degrees all in a second or so . Just wondering again , is this any harm ??
    It never goes above 90 degrees, but just wondering does teh above sound bad expecially point 2
  2. Re: Water Temperature Indicator
    Jul 2007
    hi mate,
    don't know too much about golfs as i am new to them, but from what i remember from the BMW days, what your experiencing could be one of two things :
    1) fault coolant temp sensor
    2) sticking thermostat
  3. Re: Water Temperature Indicator
    You have a common problem which is the coolant temp sensor. The new one is a superceded unit and is green, from black. They are pretty cheap, and easy to change -4minutes max!!
  1. HELP!! red temperature indicator
    By harveydog in forum Audi A3 - Archive Topics
    Last Post: 26-06-2007, 07:50 PM
  2. Temperature outside -39!!
    By stestroud in forum Passat - Archive Topics
    Last Post: 28-03-2007, 11:32 PM
  3. temperature outside -39!!!
    By stestroud in forum Archive posts
    Last Post: 24-03-2007, 12:03 PM
  4. WATER TEMPERATURE SENDER
    By taff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-11-2006, 06:30 PM
  5. indicator, temperature gauge & air con. faults.
    By Oneillboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2006, 11:17 AM
