Thread: k seal
  1. k seal
    May 2010
    edinburgh
    head gasket on the way out back pressure blowing steam out overflow on expansion bottle.
    am aware of some posts slagging k seal, in the respect it clogs up channels, and have also seen some rave reviews!
    to be honest am stuck between a rock and a hard place simply havent got the money to re do head.
    am aware of potential negatives, anyone out there used it on a pd130 with any success please!
    all input appreciated.
  2. Re: k seal
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    K seal type additives are only any good for external leaks (holes in radiator cores etc). If it is building up high pressure it is likely the gasket is blown, but check the water is circulating properly, if not it could be that the water pump impeller has come loose. Good luck.
  3. Re: k seal
    May 2010
    edinburgh
    Quote Originally Posted by Alan G H View Post
    hi alan,apparently can get my finger in to feel if pump blade is just free wheeling through the thermostat housing, so going to check that at the weekend.beyond that k seal was my only hope am broke just now!time will tell, cheers adam
  1. Question k seal
    By iangalmond in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2009, 08:34 PM
  2. Windscreen seal
    By kimi in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-10-2009, 09:53 AM
  3. Advice On Using K Seal
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 09:46 PM
  4. Steel Seal
    By mdauncey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2009, 08:26 PM
  5. Seal
    By Jakelor in forum Vento - 1994 - 1998
    Last Post: 21-10-2008, 05:11 AM
