Thread: Gear Lever Not Centering
  1. Gear Lever Not Centering
    Mar 2008
    High Wycombe
    Usually, when you let go of the gear lever in neutral, it springs to between 3rd & 4th gears.
    Well, my A3 1.8 SE 2000 AGN engine, EBD gearbox doesn't, so changing gear is a bit more hit and miss than it should be.
    Does anyone know where the centering spring is? Is it in the gearbox, or is it in the lever assembly?
    Is there anything else it could be?
    Thanks.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  2. Re: Gear Lever Not Centering
    Apr 2007
    Devizes
    Did you say in one of your other threads you've got a Haynes book? Page 7A.2 has a good breakdown illustration of the gear lever assembly and shows a couple of springs and there's a setup guide on that page that mentions some springs/collars on the transmission end of the cables as well. Can't help any further than that as I've got a lazy auto! Good luck...
    AUDI A3 1.8T 2001 X AUM AUTO LHD DENTS DIRTY-CARPETS!
  3. Re: Gear Lever Not Centering
    Mar 2008
    High Wycombe
    That's some memory!
    I did have a Haynes manual I borrowed from the library a while ago. I'll have to borrow it again.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Gear Lever Not Centering
    Apr 2007
    Devizes
    I've scanned it as a PDF, PM me your email if you want it...
  5. Re: Gear Lever Not Centering
    Oct 2011
    Bristol
    Yo Sly, any chance u could hook a brotha up with that Haynes?
  6. Re: Gear Lever Not Centering
    Apr 2007
    Devizes
    Quote Originally Posted by shane420 View Post
    Ha, depends what you need from it!? I'm not gonna send you the whole book because then I won't have one! They're only 15 quid mate if you'regonna be using it a lot or as Nick did, support your local library.
  7. Re: Gear Lever Not Centering
    Mar 2008
    High Wycombe
    Well, I'll bring this thread back from the dead:
    After my wife complaining that the car is difficult to get into gear, and it's hurting her shoulder, I had a look at it this weekend:
    I disconnected the cables at the gearbox end, and the lever springs nicely into the centre, and I can see the centring srping working there. The cables are nice and free running.
    So I followed the Audi method of aligning the mechanism (push the gear selector lever on the gearbox fully dow, turn the lever to vertical, line the gear stick up with a pin through both holes, then tighten the cable adjusters), and it's even worse - I now get reverse instead of first, and can't get 5th gear (it's like the mechanism has lined up one gate across).
    So, I lined the mechanisms up on 5th gear, and it now selects the gears OK.
    The gear lever still doesn't spring into the gate between 3rd & 4th like it should though, and when the lever is disconnected, there's no spring in the lever on the gear box (the one by the battery) - it just stays where I put it.
    Should there be some sort of centering spring on the gearbox itself?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Please Help Replacing/Removing Golf Mk5 Handbrake Lever Cover & DSG Gear Lever/Surround ?
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2009, 04:50 PM
  2. Gear Lever Bushes.
    By euroslap in forum Golf MK3 - 1993 - 1999
    Last Post: 23-09-2008, 09:19 PM
  3. Gear lever self centering
    By adzul in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2008, 12:04 AM
  4. Gear lever surround
    By Technical in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2007, 09:33 PM
  5. Passat Gear Lever
    By Westfieldmatt in forum Passat - Archive Topics
    Last Post: 20-11-2006, 03:05 PM
