Thread: Battery drain on Mk3 Golf Auto
  1. Battery drain on Mk3 Golf Auto
    Oct 2011
    Ipswich
    Can anyone be of any assistance?
    I have a Mk3 Golf Auto (1996) which has a battery drain problem. After about 2 days the battery is dead.
    I have had 2 seperate checks done on the electrics and neither checks found anything. With the engine switched off there is a negligable drain on the battery, but after 2 days there is not enought power left to power the dash clock.
    The battery is new and the alternator has been checked and is functioning correctly. I have even put a video camera in the boot and the glove box to check the lighs switch off.
    It's driving me up the wall (when it starts...) Any ideas?
    Many thanks in advance
    JD
  2. Re: Battery drain on Mk3 Golf Auto
    134 Post(s)
    2019 Post(s)
    I usually find it is an aftermarket alarm or the radio.
  3. Re: Battery drain on Mk3 Golf Auto
    Oct 2011
    Ipswich
    Hi Crasher
    Unfortunately the car has no aftermarket alarm or stereo fitted. The stereo is the factory fitted version.
    The problem started about 2 months ago and seemed to coincided with one of the cells in the battery going u/s. The battery was replaced but 2 days later it was flat. The most it has lasted with the battery connected is four days but it has flattened itself overnight.
    I was interested to see that on a thread on this forum someone had a similar problem with a Polo and it was related to the auto box fuse., but I aint no mechanic, so this may be clutching at straws.
    We are currently disconnecting the +ive lead on the battery after every trip, which is a pain, but as the car is not used every day this aint too bad. Need to get it sorted (or sold) by the winter....
  4. Re: Battery drain on Mk3 Golf Auto
    134 Post(s)
    2019 Post(s)
    When the drain was measured, was it done at a battery terminal using a multimeter and if so, what was the drain?
  5. Re: Battery drain on Mk3 Golf Auto
    Oct 2011
    Ipswich
    Hi Crasher
    The drain was initially 0.4amps but after 10 minutes this drops and hovers between 0 and 0.1amps. I checked it and also had it looked at by 2 seperate vehicle electrical engineers. The fuses have been pulled one by one while on the initial drain and this has not identified the problem.
  6. Re: Battery drain on Mk3 Golf Auto
    134 Post(s)
    2019 Post(s)
    I think a drain of 0.1 amp is a bit too high but would take at least a week to drain the battery. If the drain does not disappear when removing the fuses the drain will be on what is known as line 30 which is the unfused main power supply. I know it is new but do the test again and disconnect the alternator main power lead.
  1. Battery drain traced to auto gearbox fuse - now what?
    By mjcon in forum Polo - Derby - Lupo - Fox
    Last Post: 22-09-2010, 02:16 PM
  2. Please Help Mk3 Golf Short Cicuit Somewhere - Battery Drain
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-06-2010, 06:21 PM
  3. mk4 golf 1.9 tdi battery drain.
    By george@ggoudie. in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2008, 12:35 PM
  4. MkII Golf ECU/purge valve issue - causing battery drain
    By BillyNoMates in forum Archive posts
    Last Post: 17-01-2008, 03:03 PM
  5. Golf GT TDI Mark 5 54 PLate - Battery Drain!?!?!
    By thaidai in forum Archive posts
    Last Post: 17-01-2008, 01:08 PM
