Thread: another losing water post!
Results 1 to 9 of 9
  1. another losing water post!
    May 2010
    edinburgh
    hi all am just waiting to get waterpump timing belt done, am sure pump knackered as very little water going through return pipe.
    am having to use car for emergencies,when i do am loosing a bit of water each time out of overflow on header tank.
    my question is would a failed waterpump cause this, a build up of pressure somehow?
    am worried head gone.when i do drive it temp sits at 90 perfectly,no oily water etc.
    if anyone has had this problem and fixed it by changing waterpump,please put my mind at rest!!
    help appreciated,as ever.
  2. Re: another losing water post!
    134 Post(s)
    2019 Post(s)
    Is it a 130 PD TDI?
  3. Re: another losing water post!
    May 2010
    edinburgh
    hi crasher,ta for quick reply,yip,that the model,not bad news i hope?!
  4. Re: another losing water post!
    134 Post(s)
    2019 Post(s)
    If it only looses water when driven hard and it is clearly coming out of the expansion tank then I have seen this a lot on the 130PD and it is normally the head gasket.
  5. Re: another losing water post!
    May 2010
    edinburgh
    thanks!knackered waterpump cant give the same symptoms?
    is there anyway to pressure test for gasket leak?dont want to do belt and pump,just to find gasket gone,
    thanks again,adam
  6. Re: another losing water post!
    134 Post(s)
    2019 Post(s)
    A failed water pump would be much more obvious. Unfortunately it is very hard to test the head gasket, often it is a case of do the job and pray that you are right. Even when the head is off it is often impossible to see where the gasket has failed.
  7. Re: another losing water post!
    May 2010
    edinburgh
    ok thanks again.one last question,i saw in a petrol version thread it was possible to take out the thermostat,and check if the waterpump was ok by feeling inside,does that make any sense?!and if so can it be done on my car?and also, is there a "right" way to put in thermostat, i replaced it recently, was wondering if i could have blocked off the flow, grabbing at straws,i know!!
  8. Re: another losing water post!
    134 Post(s)
    2019 Post(s)
    Yes you can just get your finger to the back of the impeller.
  9. Re: another losing water post!
    May 2010
    edinburgh
    thanks yet again.cheers adam
  1. Losing water, but no leaks
    By phil2580 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2016, 08:55 PM
  2. Question - losing water
    By vector8724 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-10-2010, 06:14 PM
  3. Losing water
    By carlhutch22 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2010, 03:47 PM
  4. Question Losing water on my t4 1.9 TDI
    By higgy1971 in forum The Commercial Range
    Last Post: 14-08-2008, 08:08 AM
  5. Losing water....
    By mariacarroll in forum Audi A3 - Archive Topics
    Last Post: 15-09-2007, 03:33 PM
