Thread: A3 Can't remove oil filter !!!
  1. A3 Can't remove oil filter !!!
    May 2007
    Hi guys, I have a A3 1.9TDI 2000 and I am trying to remove the oil filter.
    It looks that it is very hard to unscrew it !.
    Could you please give me some hints, e.g. is it clockwise or counterclock ? Is there a special tool to do it (I am using a "Oil Filter wrench") ?
    Please help !!
  2. Re: A3 Can't remove oil filter !!!
    134 Post(s)
    2007 Post(s)
    There is a special tool (tool number 3417, available from any VW/Audi dealer) but a strap wrench should move it. It is anticlockwise. The only problem with not using the VW tool is not being able to set the required torque.
  3. Re: A3 Can't remove oil filter !!!
    Jul 2007
    If the filter is on so tight that a strap wrench keeps slipping or won't remove it, and there's enough access to do this, you could try getting a very long, strong flat blade screwdriver and puncturing the filter all the way through and then use it to turn it. A messy job, and a last resort - I had to do this on an old Fiat 127 many many years ago
  4. Re: A3 Can't remove oil filter !!!
    May 2007
    Thanks for your responce guys.
    After buying a new tool and with lots of gym training i managed to unscrew it.
    Cheers !
  5. Re: A3 Can't remove oil filter !!!
    134 Post(s)
    2007 Post(s)
    Can't do that on a Golf 4 TDI, it's an element inside a cast ally housing with a screw on plastic top.
  1. How to remove dash cluster?
    By JiminBahrain in forum A8 - S8 - V8
    Last Post: 03-06-2007, 06:39 PM
  2. Remove Door pins
    By Stu_c in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2007, 04:32 PM
  3. How to Remove ECU from Golf MK5 2005?
    By rj4eva in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2007, 09:23 PM
  4. How to remove Concert stereo?
    By Humph in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-04-2007, 10:42 AM
  5. Remove Door Panels
    By starhannes in forum Archive posts
    Last Post: 22-02-2007, 06:12 PM
