Thread: Stop engine/oil pressure warning light comes on
Results 1 to 8 of 8
  1. Stop engine/oil pressure warning light comes on
    GnasheRRR Guest
    Volkswagen Passat 2.0tdi 170 and the yr. 2007 engine code is bmr
    Start the engine and all is good but go to drive away at 1800/2000rpm and the
    Stop engine/oil pressure warning light comes on.
    I have had the following parts fitted.
    Oil pressure sensor
    Oil pump drive
    new oil
    oil pump
    balance shaft ***.
    After each 1 was fitted the car was started and the same thing happens each time so I have fitted a oil pressure gauge and the pressure is 50psi at 800rpm and 70psi at 2000rpm.
    HELP HELP I NEED HELP PLEASE
    Thanks in advance
    GnasheRRR
  2. Re: Stop engine/oil pressure warning light comes on
    135 Post(s)
    2036 Post(s)
    You need to look at the measuring blocks for the instruments to make sure the dash is seeing the oil pressure signal.
  3. Re: Stop engine/oil pressure warning light comes on
    DSG4ME Guest
    DON'T Drive it, you may be a victim of the pump fail, driving it will make it worse.
  4. Re: Stop engine/oil pressure warning light comes on
    GnasheRRR Guest
    Hi Crasher, can this only be done via a VW Diag?
    Hopefully will be something like this as all else done and mechanical oil pressure shows good.
    Appreciate your response, thank you.
    Regards
    GnasheRRR
  5. Re: Stop engine/oil pressure warning light comes on
    GnasheRRR Guest
    Yep, not driving it as worried it may do damage, although I deffo have good oil pressure as a mechanical gauge does not lie. It has to be a sensor or as Crasher says.
    Will do more digging. Thanks for response anyway.
    Regards
    GnasheRRR
  6. Re: Stop engine/oil pressure warning light comes on
    135 Post(s)
    2036 Post(s)
    You need a diagnostic system that will show measuring blocks such as the VAG system or VCDS (VAG-COM).
  7. Re: Stop engine/oil pressure warning light comes on
    DSG4ME Guest
    Quote Originally Posted by GnasheRRR View Post
    Regards
    GnasheRRR
    As long as you are sure the pump is driving the oil ok it should indeed turn out to be a sensor.
    I'd re-check any wires and pipes to it as well in case you've forgotten something, or a wire has broken, try to trace it back and look for kinks etc.
  8. Re: Stop engine/oil pressure warning light comes on
    GnasheRRR Guest
    Had to give in and take to VW dealer.
    They identified almost immediately that the cause was a break in connection to the signal for the oil pressure. Crasher, you hit the nail on the head m8.
    So the £1800 I spent on all the other stuff was not needed at this moment, but the balance shaft was indeed severely worn and would have let go soon, so at least with all that work done I should not need worry about for a while now.
    The VW technician found the break in the wire just behind the dash and cut and re-joined it and all is back to normal again.
    Many thanks to you all for your input. I think these forums are invaluable.
    Thanks again, and happy motoring
    GnasheRRR
  1. Audi Cab Oil Pressure Warning Light - Engine gone?
    By nricha in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-03-2009, 12:54 PM
  2. oil pressure warning and STOP sign , help needed!!
    By toledo999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2009, 08:32 PM
  3. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  4. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
  5. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
