Thread: Flashing Engine Light & Constant Exhaust Warning Light
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Flashing Engine Light & Constant Exhaust Warning Light
    Norfolk
    Quote Originally Posted by Tups1974 View Post
    Yes it is some flap on the throttle motor on the front of the engine, car should be done tomorrow and I'll be £391 lighter.
    Diesel engines don't have a throttle or a throttle motor which is why a proper code read helps. Make sure the dealer checks the fuses. The antishudder valve often jams and blows the fuse. If the fuse blows, your radiator fans won't work.
  2. Re: Flashing Engine Light & Constant Exhaust Warning Light
    Feb 2011
    Portsmouth, UK
    I will ask the dealer to check but just in case which fuse do I need to check myself?
    2014 VW Golf GT 2.0TDi Bluemotion
  3. Re: Flashing Engine Light & Constant Exhaust Warning Light
    DSG4ME Guest
    I'd check em all, the manual is wrong in saying which fuse serves which circuit anyway, just do em one at a time and don't forget which slot you pulled it from, there are fuses on both sides of the dash, and some more larger ones near the air filter and battery.
  4. Re: Flashing Engine Light & Constant Exhaust Warning Light
    Feb 2007
    Swindon
    I guess you got your car fixed in the end, can you let me know what the exact problem was?
    My 58 plate CR 140TDi is due into the local VW dealer with the exact same issue aas your car had.
    When the the car gave out the warning ping along with the "Engine fault - Workshop" message, my glow plug warning light also flashes.
    Fingers crossed mine will be covered on the Das Auto used car warranty!
  5. Re: Flashing Engine Light & Constant Exhaust Warning Light
    Feb 2011
    Portsmouth, UK
    The car was fixed it was some flap motor in the engine part no 03L128063E the job cost £391.31 in total
    All I see is a shinney ally box about 2x3 inches in size with an electrical connector off it at the front of the engine bay on the black plastic pipework that cost the best part of £400 quid
    Regards, Bill
  6. Re: Flashing Engine Light & Constant Exhaust Warning Light
    Norfolk
    That will be the anti-shudder flap.
  7. Re: Flashing Engine Light & Constant Exhaust Warning Light
    #17
    Jul 2008
    I have the same problem with my 58 plate Audi A4 TDI. Recovery guy diagnosed P2102 and reset the code, which cleared it for a day before reappearing. But now appears and disappears intermittently over the last 3 weeks, normally appearing if the car has not been driven for a couple of days. With Audi on Friday for their opinion.
  1. ABS warning light & flashing brake light
    By mrbiondi in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2011, 01:47 PM
  2. Flashing Engine Warning Light and Buzzer
    By Marty4475 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2008, 09:21 AM
  3. Engine management & flashing coil light
    By JohnWithAGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 09:03 PM
  4. Engine Warning light flashing and car juddering! Help
    By veej123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2008, 09:25 PM
  5. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
