Thread: ABS Pump 03 Passat TDi 130
  1. ABS Pump 03 Passat TDi 130
    Dec 2007
    Hello Guys,
    Just wondered if anyone had had a ABS pump repaired or refurbished and did it work okay afterwards, I've seen it advertised for £100 with a two year guarantee and it seems worth the cost for my 8 year old car rather than replacing with the unit from vw at close to £1000 pounds.
    Thanks in advance!
  2. Re: ABS Pump 03 Passat TDi 130
    Norfolk
    bba-reman should be able to fix it for you. It is often an internal electrical fault.
  1. Please Help Passat TDi 130 OEM Water Pump Warranty???
    By jclarkeuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2011, 04:13 PM
  2. Lift Pump Passat 130 TDi
    By jim_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-08-2010, 09:07 AM
  3. Passat - ABS Pump Fault 2005 130 TDI Highline Estate
    By feldon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2010, 09:15 AM
  4. passat 130 water pump
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 10:12 PM
  5. 2003 VW Passat 1.9TDI 130 - ABS/ESP warning light!
    By nick.king in forum Archive posts
    Last Post: 03-02-2008, 07:00 PM
