Thread: Engine noise
  1. Engine noise
    Sep 2011
    wigan, UK
    Have noticed a ticking noise coming from around the cam cover / oil filler cap, on tickover (gets faster as you rev the engine ) even when engine is cold or at normal temprature.When I remove the oil filler cap it gets louder. Its an A4 B7 170 2.0 tdi (57) plate 2008 with 82700 miles on the clock. Has anyone any idea's what it could be.
  2. Re: Engine noise
    Jan 2011
    Chester
    sounds like a noisy hydraulic lifter - if it is, then should be nothing to worry about - check that you're using the right viscosity oil.
  3. Re: Engine noise
    Sep 2011
    wigan, UK
    Cheer's s-express .would anyone recomend a quality engine oil to use, Ill drop the old oil & replace it to see if this works.
  1. Engine 'swishing' noise - AUS engine
    By rjamey_uk in forum Bora - 1998 - 2005
    Last Post: 05-09-2013, 07:34 PM
  2. engine noise - pulleys or bearing noise
    By johnmccracken in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2011, 02:28 PM
  3. Question Engine Noise
    By stevencevans in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-05-2011, 04:37 PM
  4. Engine Noise
    By furrybean in forum Golf MK4 - 1999 - 2004
    Last Post: 13-06-2009, 06:28 PM
  5. noise from engine
    By bakili in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-11-2008, 08:40 PM
