Thread: Buying 2008 TDI
  1. Buying 2008 TDI
    Sep 2011
    Ayrshire
    I'm thinking of buying a Passat 2.0TDI, and have been looking through reviews online. My other options are Audi A3 or A4.
    Apparently the Passat engine changed to a common rail in 2008. How can I tell if I'm getting the new engine when I look at a car - I'm wary of trusting the registration date in case of "old stock" being sold by a dealer when new.
    The only other problem I've heard of is a sticky handbrake, id there anything else I should be looking for?
    Cheers!
  2. Re: Buying 2008 TDI
    Sep 2011
    Ayrshire
    I guess I should have searched the forum before posting, I've found the answer I was looking for re the CR engine!
    Any more buying advice would be welcome though!
  3. Re: Buying 2008 TDI
    Mar 2010
    london uk
    i guess the plastic cover of the engine - the PD lines are straight ,the CR are on an angle that to give you an idea not to be fooled by dealers.Good luck with your purchase,search good the forums with issues of your options.
  4. Re: Buying 2008 TDI
    Mar 2010
    london uk
    If you don't want loads of space i would personally go for the a4 the LED strip at the front and back plus the inside looks and quality is above the passat.
  5. Re: Buying 2008 TDI
    DSG4ME Guest
    Buy a CR if you are going to, the PD is too potentially problematic.
  6. Re: Buying 2008 TDI
    Apr 2007
    France
    12 Post(s)
    I'll chip in with my usual "make sure you get both 'keys'."
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Buying 2008 TDI
    Sep 2011
    Ayrshire
    Thanks for all your advice. Now does anyone know if the Jetta got the CR engine at the same time?
  1. Question I'm thinking of buying 2008 A8 SE 3.0 TDi
    By blackrain in forum A8 - S8 - V8
    Last Post: 26-01-2011, 11:07 PM
  2. Buying a 2008 A5
    By bobmccarthy in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 02-06-2010, 08:54 AM
  3. Advice on buying a 2008 Caddy Maxi?
    By The Dude in forum The Commercial Range
    Last Post: 27-02-2010, 01:48 AM
  4. buying advice please ref audi a4 avant quattro s line 2007 or 2008
    By martin73 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2010, 03:09 PM
  5. 2008 A4 2.0 TDi radiator to fit 2006 A6 2.0 TDi??
    By chodecz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-06-2009, 07:32 PM
