Thread: A6 auto revving slightly
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. A6 auto revving slightly
    Aug 2011
    London
    Hi all,
    I have noticed something strange with the A6 this past week. When I amdriving at a steady speed and take my foot off the accelerator, like normal therevs drop to around 1000 rpm. But i have noticed at this point something thatfeels strange to me, the car revs gently between 1000 rpm and sometimes up to1200/1250 rpm and continues to do this until i either slow down or i put myfoot on the accelerator again. It is almost as if the car is hunting for anidle if that makes sense. Normally this wouldn’t bother me but where the car isgently revving you can feel a rocking motion as such due to the revving. It’senough to be annoying and wanted to find out if anyone else has this problem oreven if it is a problem.
    The car has just had a full service by my garage and the following changed:
    Full service
    Oil and filter change
    Air fliter change
    Gear box oil and filter change
    Fuel filter change
    Coolant change
    diff oil change
    Power steering oil changed
    Brake pads changed and brake fluid changed
    I did take it back to the garage and they found a fuel pressure regulatorfault code or something to that effect. They siad this might have been due tothe new fuel filter being changed. They cleared the code but the problem stillpersists.
    Any ideas guys?
    Tubbs
  2. Re: A6 auto revving slightly
    Jul 2011
    Scotland uk
    I have noticed that mine does it too.
    Although at higher speeds when you lift off the throttle, the car seems to coast more with little or no engine braking.
    Its only at lower speeds when I lift off the throttle that the "problem" you describe exists. I have almost convinced myself that its just the auto box deciding whether to downchange or not?
    I have a 3.0 TDI auto Le Mans
  3. Re: A6 auto revving slightly
    Turn the A/C off for a few days and see if it still revs by itself. Regards Peter
  4. Re: A6 auto revving slightly
    Aug 2006
    Thessaloniki, Greece
    This happens to me only when I go downhill and the engine is cold. Once the engine is warm this doesn't happen.
    2006 Audi A6 Allroad 3.0 TDI Tiptronic
  5. Re: A6 auto revving slightly
    Jul 2011
    Scotland uk
    Yep! forget what I said, I have to agree with what Gianton says. I just went out to the park with the dog and on the way back when the engine was up to temp, it didnt happen.
    What causes this? I have no idea.
    Aug 2006
    Might be a way to warm the engine faster. Diesels engines get warm harder than petrol ones.
    Maybe someone with a petrol engine can chime in to confirm that.
  7. Re: A6 auto revving slightly
    46 Post(s)
    Can't say I've noticed this myself when driving. My engine is currently warm so I will have a look when its cold.
    Aug 2006
    I live on the top of a hill and every morning I have to drive downhill on the way to work. This revving up and down was from the day I got my car 4 years ago. I remember my ex BMW 528i wasn't doing that.
  9. Re: A6 auto revving slightly
    46 Post(s)
    Noticed this morning that my car does this too, never noticed it before until the question was asked.
    Seems to be normal
  10. Re: A6 auto revving slightly
    Aug 2011
    London
    The slight revving wouldnt bother me at all, its just the hesititation in the engine that makes the car feel like it rocking back and forth slightly when not accelertaing that is a little annoying. It just doesnt feel smooth, this being my first auto i have nothing to compare it with but ive never experienced this feeling with any other car even when as a passenger in an auto.
    I did take it back to my garage and they did find a fault code which was the 'fuel pressure regulator' (didnt get the code unfrotunately). They said this might have logged when they changed the fuel filter. They cleared the code but it still does it. They have the car again to do a deaper check. I will let you know if anythign comes up guys.
    Tubbs
  1. Slightly lumpy dle-tried everything..Help!
    By xpeterpx in forum Golf MK4 - 1999 - 2004
    Last Post: 16-06-2010, 11:22 AM
  2. V6 auto..... Over REVVING
    By SPECKSTER in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-04-2010, 12:26 PM
  3. Am I slightly 'off'?
    By Hippogriff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-11-2009, 05:41 PM
  4. A4 heating slightly
    By Stevie33 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-09-2009, 08:28 PM
  5. Slightly down on power 2.5 tdi v6
    By ßÛŠΤΞЯ in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-09-2009, 01:15 AM
