Thread: RNS-E radio reception please help
  1. Unhappy RNS-E radio reception please help
    redders80 Guest
    I have had problems with my radio reception for sometime now and it is only getting worse. Radio 1 is hissy at best and sometimes it doesn't even show it on the radio screen, and i only have 2 or 3 stations available. Anyone had this problem or know of any quick checks??? Thanks
  2. Re: RNS-E radio reception please help
    May 2008
    Saloon? Avant? Cabrio? Was RNSE factory fitted? Or a retro-fit?
    Could be a problem with the antenna or the cabling to it, Have a VCDS fault scan done to point you in the right direction.
  3. Re: RNS-E radio reception please help
    redders80 Guest
    Yeah sorry it's an Avant and its original fit. i have ordered the tools to pull the unit to check connections behind, where else should i be checking???
    Thanks all
  4. Re: RNS-E radio reception please help
    Jul 2010
    Bracknell
    I am not sure how the aerial is wired on the Audi but on my old BMW which also had the aerial built into the rear window there was a separate aerial amplifier near the window. A few people had the same problem you were having and it was often caused by a broken power cable to the amp or the connector becoming disconnected.
    2006 Audi A3 2.0 TFSI Quattro S-Line Special Edition
    May 2008
    Quote Originally Posted by redders80 View Post
    Thanks all
    Check the connections on the rear window antenna (side windows in the avant contain the aerials). A VCDS fault code scan is worthwhile before you start pulling the car apart. Could be a faulty antenna amplifier amongst other things.
  1. Please Help A3 - No radio reception
    By jonnersp in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-12-2010, 10:25 PM
  2. FM radio reception
    By burkey1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2010, 12:53 PM
  3. No radio Reception - RNS-E
    By boulevard in forum In Car Entertainment
    Last Post: 04-07-2010, 09:12 PM
  4. poor radio reception on aftermarket radio
    By pukrik3@pukrik3 in forum New Member Introductions
    Last Post: 23-07-2008, 09:21 AM
  5. Radio Reception
    By Teg in forum Audi A3 - Archive Topics
    Last Post: 10-05-2007, 06:28 PM
