Thread: Coolant Leak!
  1. Coolant Leak!
    May 2007
    Liverpool
    I have a coolant leak in my 130 tdi, After a big serch I have found it coming from the o/s, It only really is a small leak, I have to top it up every two weeks.
    Should I put radweld in or get a new radiator?
    Thank you plesae!
  2. Re: Coolant Leak!
    Oct 2005
    Lutterworth
    The only thing I would put in the coolant is G12+
    Put a new rad on then you know its good.
    That's an early failure for the rad. Both the ones I replaces lasted over 120K and 6 years.
    Is it the usual failure at the plastic\metal joint ?
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Re: Coolant Leak!
    May 2007
    Liverpool
    Quote Originally Posted by Lex Luthor View Post
    I can't really tell the leak is at the extreame left of the radiator as you look at it, so i asume it is the plastic/metal joint.
    I read a thread a while ago saying it was quite common even for 'young' low millage cars. I'll try and find it, the bloke said his mate told him who is a VW tech.
    But as my luck is going lately its no surprise to me.
  4. Re: Coolant Leak!
    Verwood, Dorset
    I have a slow leak as well, but have not seen it on the rad yet.. But then again I have not had a 'propper' look, I need to take the bumbper off to do this. How difficult is it to take it off? And are there any things I need to watch for when taking it off? Like sensors? Oh and I have headlamp washers, so I suppose they will hinder my pogress..
    Just don't want to break anything that will cost a bomb at the ********
  5. Re: Coolant Leak!
    Mar 2007
    The heater matrix is a very common problem with passats. Mine was leaking,its location is at the very back of the engine compartment and the part cost is £20. ( its actually the rubber sealing ring inside the hose)
  6. Re: Coolant Leak!
    May 2007
    Liverpool
    Quote Originally Posted by sherlockuk View Post
    The bumper is fairly easy to take off (although I have never taken one off fitted with washers) There is about 5 screws in each wheel arch a couple on the top of the bumper, take the grille off then there is a few more and I thing some underneth. Then it simply slides off. Getting it on is the reverse but I would advise you got some help because it is a bit tricky lining it back up on your own it can be done but just fiddley.
    This is where is found the leak's origin, I knew is was losing coolant but couldn't find where from. I was changing my cambelt so I had all the front of the car off. Only then did the leak become apparrent as things were being moved around and I noticed a small amount coolant on the floor.
  1. A3 coolant leak
    By hensojm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2009, 12:22 PM
  2. VW Bora PD115 Coolant leak
    By vwtom in forum Bora - 1998 - 2005
    Last Post: 05-10-2008, 10:40 PM
  3. Trans oil or coolant leak....any help?
    By Daza-1979 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:53 PM
  4. Coolant Leak into Passenger Footwell
    By kts in forum Passat - Archive Topics
    Last Post: 25-01-2007, 01:46 PM
  5. Coolant Leak - Head gasket?
    By Jethro.64 in forum Passat - Archive Topics
    Last Post: 12-09-2006, 07:52 AM
