Thread: CV Boot (thrust washer and curved washer)
Results 1 to 9 of 9
  1. CV Boot (thrust washer and curved washer)
    Sep 2008
    6 Post(s)
    Did both CV boots (outer) at the same time I did the lower arms on my 2.5TDI quattro avant. When I turn the steering full lock to full lock I can hear a slight click. The joints were not dry (I replaced both boots before they split) and there was no noise before, but I suspect I may have inadvertantly put the thrust washer and plastic curved washer back on - the wrong way around? Can anyone please confirm?
    It's currently fitted with the fixed circlip nearest the transmission side of the driveshaft, then the metal thrust washer, plastic curved washer (smallest cone end facing the CV joint), then the metal clip in the splined driveshaft - that the CV joint engages when knocked into position. Should the metal thrust washer be next to the CV Joint?
    Can't believe I'm going to have to strip the whole lot out again - but needs must. Think I was distracted doing the lower arms!
    2016 BMW i3 REx (80k)
  2. Re: CV Boot (thrust washer and curved washer)
    Sep 2008
    6 Post(s)
    Found this on another site - so looks like I put it on the right way. Should the metal thrust washer sit flush with the plastic curved washer? Looking at this picture - it looks although the metal washer on the drive shaft faces the other way?DSCN1068.jpg
  3. Re: CV Boot (thrust washer and curved washer)
    london/ UK
    I put the concave washer with the dished side towards ther cv joint then the plastic washer as in the picture (with the small side towards the cv joint) then the circlip on the shaft. You might have a bolt on the suspension arms which is not fully tighten i think !
  4. Re: CV Boot (thrust washer and curved washer)
    Sep 2008
    6 Post(s)
    Quote Originally Posted by adamss24 View Post
    Thanks for that - appreciate it. I'll check the arms just in case. I intend to jack the car up again with both front wheels off the ground and turn the steering to see if I can isolate the noise. It must be the CV, as it wasn't clicking before. To confirm - as your answer regards the metal washer can be interpreted two ways - or maybe it's just me! You're saying the metal thrust washer should face the CV joint rather than away from it (dish base - next to the metal circlip)? This picture is closer.CV Boot_Close.jpg
  5. Re: CV Boot (thrust washer and curved washer)
    Jul 2011
    Leicester
    If it helps I have literally just done mine and it was the same as the picture. I have no noise so looks like you have it right.
  6. Re: CV Boot (thrust washer and curved washer)
    Jan 2009
    Nuneaton England
    6 Post(s)
    I have replaced the offside cv joint on my son in laws A4 1999 1.6 Today and its the same has the photo
    Working from the outer end of the shaft: - Circlip - Plastic spacer small end outer most - Metal washer dished side towards plastic spacer
  7. Re: CV Boot (thrust washer and curved washer)
    Sep 2008
    6 Post(s)
    Thanks. I jacked up the car and there's no noise from either CV joint, hard lock to hard lock, rotating wheels, etc. There is a slight click (while turning the wheel) in the car, that's possibly coming from the steering column. Frankly I'm not investigating it any further - as it passed the MOT, and that's good enough for me. A worn power-steering assembly is a whole different ball game. Incidentally - it doesn't leak power-steering fluid!
  8. Re: CV Boot (thrust washer and curved washer)
    Jan 2009
    Nuneaton England
    6 Post(s)
    Good all OK
  9. Re: CV Boot (thrust washer and curved washer)
    Apr 2007
    North|East UK
    Thanks for this thread
  1. Question Removing Avant boot door liner - washer water not coming out of washer!
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-03-2011, 11:22 AM
  2. Rear washer
    By john dollar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2010, 11:27 PM
  3. Please Help Mk 4 washer jet
    By jaybo79 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2010, 01:37 PM
  4. Boot Light, Washer Bottle Warning Lamp, Glovebox Light,
    By jonathanfenton in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2008, 10:26 PM
  5. Pressure Washer
    By prolfe in forum Chat - Completely Off Topic
    Last Post: 30-08-2007, 05:49 PM
