Thread: Where is the Blue Tooth Module located when factory fitted
  1. Where is the Blue Tooth Module located when factory fitted
    Aug 2011
    Aldershot
    6 Post(s)
    So I remember reading a post but I can't find it now, Audi put this blue tooth module inside an electronics box under a seat? But on a UK Right hand drive car is this under the drivers or passenger seat?
    If I don't have vcds and want to know for sure that I don't have this fitted before buying and retrofitting, where should I start looking?
    Paul
  2. Re: Where is the Blue Tooth Module located when factory fitted
    May 2007
    knee deep in clunge
    14 Post(s)
    search bluetooth with your phone when sat in the car, also it will be phone preparation so there will be a base plate in the centre arm rest or mounted on the dash next to the radio
    or lift the passenger seat and carpet look for a black plastic box and open it
  3. Re: Where is the Blue Tooth Module located when factory fitted
    Jul 2010
    Lichfield
    Hi A8 tech, Sorry to bother you, but from various links on hear i hope you can help. Just bought an A8 2007-57 SE 3.0tdi,with all the bits, but my phone Samsung galaxcy S11 does nt hook up for phone book,and is a little temp with connection or not,and i can only dial out on a few no that i ve already called or recieved whilst in the car, and i cannot work my phone when its connected to the car,it has to be throught the car system.
    Sorry for what may be daft questions, but a little confused with it,great car though!
    Kind Regards
    John
  4. Re: Where is the Blue Tooth Module located when factory fitted
    May 2007
    knee deep in clunge
    14 Post(s)
    well you may well have a problem that can not be resolved
    looking here http://microsites.audi.com/ngw_asset..._UK/index.html it shows the phone is not supported
    and as there is no sim card reader with mmi 2g high then you can not upload the contacts to a sim card and transfer
    so you can either manually transfer the contacts or try using the sim card in another older phone and see if you can save them that way.
    as for the connection then your dropping out on bluetooth or gsm which is unavoidable if not fully compatible
    whilst the phone is bonded then you use the phone via the speech dialogue system or multi function steering wheel or via mmi controls
    If you have rsap then bond via rsap and move the phone contacts to the sim
    If you have handsfree profile then move the contacts to the phone and again try to transfer your contacts
  5. Re: Where is the Blue Tooth Module located when factory fitted
    Jul 2010
    Lichfield
    Will have to live with the phone dropping out every now, and then due to not been fully bonded, but thanks for advice on transferring sim to older phone, and then connecting to load phone book that worked a treat, and then back to my phone, and still all down loaded, so can now call from car system all my contacts. Your a star!
    One more thing from what you said regarding manual transfer, which is how can i transfer individual contacts from my phone if i add any more later, without having to change sim to an older phone again.
    Thanks again for advice.
  6. Re: Where is the Blue Tooth Module located when factory fitted
    May 2007
    knee deep in clunge
    14 Post(s)
    its easiest to repeat this process again but just try adding a new contact and next time you use the vehicle allow 10 mins or so then scroll through to see if its added the new contact
    would be interesting to see it now adds the contact
  1. Blue tooth phone prep
    By skymaster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-06-2012, 06:06 PM
  2. Blue tooth connection lost?
    By Phil Harmonic in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-09-2011, 09:30 PM
  3. Blue Tooth Issue Cant Be Heard !!!
    By fingers1963 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-07-2010, 09:49 AM
  4. A4 blue tooth issue
    By Janfi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-03-2010, 04:44 PM
  5. blue tooth hands free kit
    By jeepster1961 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-11-2009, 11:01 PM
