Thread: 1999 AFN 1.9 TDI serpentine belt replacement
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
  1. 1999 AFN 1.9 TDI serpentine belt replacement
    Hi there,
    I own a 1999 Passat 1.9 TDI. Engine code AFN.
    My serpentine belt tensioner is faulty, and needs to be replaced as soon as possible.
    I got my new tensioner in the mail today, but cant understand how to replace it.
    Have tried to search the forum, but only found info about the 3BG tensioner.
    Any writeups, or tips regarding this? How do i get the tensioner out, and the new one in? Can't i just replace the wheel (with bearing) ?
    I don't want to put the lock carrier in service position if its not absolutely possible.
    Thanks!
    - Lars
  2. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    132 Post(s)
    1980 Post(s)
    I can't do it with the front end in place, I simply can't get my hands and arms in there.
  3. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    Is there enough space to get the tensioner out? Or does the fan need to be removed? Also how is the tensioner fastened?
  4. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    132 Post(s)
    1980 Post(s)
    I don’t know, I have never done it that way. I pull the front forward on the pins, remove the fan, then the belt and then change the complete tensioner. Also, whilst in there, check that the alternator one way cutch is working, the pulley should drive clockwise and slip anti clock. These pulleys failing are the main reason the tensioner fails.
  5. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    The pulley is the alternators ribbed wheel that the belt rides on? And it should only be possibe to turn clockwise, and not counter-clockwise? Or how do i know if it is working?
    Sorry about my english, it isnt as good as it could have been..
  6. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    132 Post(s)
    1980 Post(s)
    The pulley (the ribbed wheel) should only drive the alternator clockwise, if you hold the internals of the alternator still carefully with a screwdriver (battery disconnected!), the pulley should slip anticlockwise after overcoming the internal friction. Your English is fine and no doubt a lot better than my knowledge would be of whatever your first language is…
  7. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    Thanks. I will check the alternator pulley when i get home from work.
    I'm from Norway by the way..
  8. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    132 Post(s)
    1980 Post(s)
    The way Europeans can communicate in English always makes me feel embarrassed the we in the UK hardly ever have a second European language, we are lucky in some ways that English has become universal. In fact some British people cannot write in English as well as you can!
  9. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    I am in the garage now, removed the serpentine belt. Tried to hold the internals of the alternator still carefully with a screwdriver like you supposed. While doing that i can not turn the pulley clockwise or counter clockwise. It moves until the "blades" hit the screwdriver, and then its locked.
    Does that mean that the pulley is defective? How can i be sure that my alternator has this pulley ?
  10. Re: 1999 AFN 1.9 TDI serpentine belt replacement
    The alternator part number is 038903018BX01
  1. Question A4 AFN TDI Clutch replacement
    By chuffingaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2012, 11:59 AM
  2. 1999 1.9 110 TDi Serpentine Belt Question???
    By Flatcap in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-03-2010, 01:40 PM
  3. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
  4. A6 1.9 TDi AFN Timing Belt Change
    By newmancp in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-01-2009, 09:00 PM
  5. Radiator Leak 1999 A4 1.9 Tdi AFN engine
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2008, 07:24 PM
