Thread: coding - how to get this!
Results 1 to 8 of 8
  1. coding - how to get this!
    May 2008
    I hope you can help me understand this!
    here's my log, how to get the read one?
    Passat CC 1.8 TSI
    Address 03: ABS Brakes
    Control Module Part Number: 3C0 614 109 AF
    Component and/or Version: J104 C4 440 V2 0015
    Software Coding: 0000000
    Work Shop Code: WSC 05311
    Gateway Installation List,
    Sunday,04,September,2011,23:51:18:26365
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Fredj's Workshop
    Gateway Installation List: 3C0 907 530 Q
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    Any help would be appreciated.
    46 Post(s)
    Update your vcds version. What sort of lead are you using? Genuine or eBay?
    Also are you using the correct lead for your car? Most ebay leads won't function correctly with the newer cars iirc (2005 onwards I think)
  3. Re: coding - how to get this!
    May 2008
    Thanks for the quick reply, i can't update it because its chainse vag-com 704.
  4. Re: coding - how to get this!
    Aug 2011
    Immingham, Lincolnshire
    Now that's a problem. I defo would get the genuine lead. Where do you live. Maybe someone with genuine lead can look into it?
    May 2008
    Quote Originally Posted by Touran200409021 View Post
    Stop using ripoff fakes and use the genuine article and it'll work a treat.
    2 0 0
  6. #6
    46 Post(s)
    x2, support the people who created the product and not Chinese who copy it.
    I'd say the lead is the problem in this case.
  7. Re: coding - how to get this!
    Sep 2009
    Apollo
    Thanks guys!
    Touran200409021,
    3C Passat ABS coding is done online at the dealer but in most cases we can assist with the coding on these systems IF the inquiry is from a customer (meaning someone using our genuine product) and a registered user. Also see this:
    https://www.vwaudiforum.co.uk/forum/s...AG-COM-Section
  8. Re: coding - how to get this!
    May 2008
    Thank you to all of you, i have the ABS Brakes coding number and everything is OK now.
  1. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  2. ECU Coding
    By toniz in forum VCDS - Help Requests
    Last Post: 13-03-2011, 07:35 AM
  3. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
  4. Bloetooth Coding
    By speedybiker in forum VCDS - Users Locations
    Last Post: 31-07-2010, 02:31 PM
  5. Mfd coding
    By haydengoy in forum In Car Entertainment
    Last Post: 15-03-2009, 07:48 PM
