Thread: Audi A4 Broken Springs How hard to change?
  1. Audi A4 Broken Springs How hard to change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All
    My Audi A4 V6 2.8 Quattro Saloon R reg (likes spending my money LOL)
    Noticed a couple of strange clunks from front and rear suspension over the last few days
    Jacked it up tonight Off Side Front & Off Side Rear Coil Springs both broken
    How hard are they to change?
    Thanks all
  2. Re: Audi A4 Broken Springs How hard to change?
    6 Post(s)
    In the middle of doing the suspension on mine. The fronts are relatively straight forward. Ideally you need to change in pairs. If you've already got a broken front, then the other side probably won't be far off.
    For the fronts, chock the rear wheels, and use a trolley jack to raise. Get a couple of jack stands in there for peace of mind. In the engine bay there are three bolts that hold the strut in place, 17mm from memory, loosen but don't completely release. You'll probably need to move the plastic trim here to gain access.
    Now the hard work. You need to remove the pinch bolt on the strut which holds the upper control arms in place. Nine times out of ten it's seized - but you might be lucky. It's 16mm both ends. The nut will come off but the bolt will refuse to budge. Soak in WD40 or Duck Oil penetrating release and leave for a while. Wire brush and clean the area. This bolt can be knocked out with brut force. However the secret is to get something heavy onto it, at the right angle. Turn the steering so the bolt is at facing you. Using a decent lump hammer and a punch of some description - to aid, give a series of heavy direct blows. You may need a little heat, however this will damage the upper control arms - which will probably require changing anyway.
    If the bolt comes out - congratulate yourself... this is the worst part of the job!
    On the spring itself, put a couple of spring compressors on it and compress as far as you can. Make sure you get a proper grip on the spring, although it's broken there's still a fair bit of tension in it. More often than not - it's just the end of the spring that breaks. With it compressed, you can release the upper bolts in the engine bay. In addition there's a 18mm bolt through the lower control arm. Release this too. The strut can now be removed. If it won't drop out - there's normally a small pressed clip to be removed.
    With the strut out - you can now go about removing the top mount. It's held in place with a couple of small nuts. Remove them. The main bolt on the strut needs to be removed. You'll need an allen-key and offset ring spanner to get a grip.
    Check the condition of the shock absorber itself (make sure there's no leaks or weeping). Any damage or deterioration to the bump-stops, then replace this too. The top mount should be okay. I changed these on mine at 127k, but quite honestly they were fine.
    Withe the old spring out - fitting is as reverse. Make sure the spring is seated properly (needs to fit within the pressed metal guides on the strut seat). If the upper control arms are worn, and I'd put money on it, then replace these too. Trust me - it's easier to do this now with the strut out. Position the new arms at the same height as the old ones. With the strut back in position, jack it up slightly with a scissor jack to compress it slightly. Pull the control arms down and lubricate with marine grease or similar. Use a new pinch bolt and secure.
    Torque the bolts in the engine bay and lower control arm. Now the spring can finally be released. Refit wheel, lower car and double-check the bolts in the engine bay.
    This is a good video. http://www.youtube.com/watch?v=OtwR4bgA_x0
    I haven't done the rears, however as I understand it - you need to remove trim inside the boot area to gain access. Good luck.
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  3. Re: Audi A4 Broken Springs How hard to change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi Spartacus 68
    Thanks for your assistance
    Sounds like I will be ordering more parts than first envisaged (normal Audi practise lol)
    Do I have to go to Audi for the pinch bolts?
    Are there any further pitfalls I may come accross in replacing the upper control arms at the same time?
    Happy days
  4. Re: Audi A4 Broken Springs How hard to change?
    6 Post(s)
    Quote Originally Posted by mumutley View Post
    Hi Spartacus 68
    Happy days
    Yes, Audi for pinch bolt. If it come out okay - it's plain sailing.
  5. Re: Audi A4 Broken Springs How hard to change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi there
    I rang local car spares outlet today they and had a quote for 4 x upper suspension arms and 2 x pinch bolts £94.00 all inc
    Then I found this offer on Ebay http://www.ebay.co.uk/itm/310333005906?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_2135wt_905
    4 x upper suspension arms 2 x track rod ends 2 x drop links 4 x lower suspension arms along with full nut and bolt fitting kit total £98.99 all inc
    I live 15 minutes away from local spares outlet and 40 minutes away from this Ebay spares outlet
    Personal I think its a no brainer
  6. Re: Audi A4 Broken Springs How hard to change?
    6 Post(s)
    You get what you pay for. I must admit I was tempted with some of the Ebay parts as I wasn't prepared to pay for genuine Audi components given car is now 10 years old and 127k on the clock. That's not to say I'll put any components on though. I've just finished the driver's side and fitted the lower control arms. It's more difficult than the upper control arms, as everything is on tight, access is difficult without ramps, and it's all original components. I paid £140 for lower arms (budget). To give you a comparison, a genuine Meyle kit comes with everything including bolts and 4 years guarantee for £390. I'm not planning on doing this job twice. As long as I get 2-3 years out of them - I'm happy.
  1. Please Help Broken Springs
    By tpl288 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2011, 09:42 PM
  2. How hard to change downpipe on 2.0 tdi
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 14-12-2010, 07:34 PM
  3. clutch change. how hard??
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-10-2010, 11:50 AM
  4. AFB engine thermostat change...how hard
    By martink in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-09-2008, 10:28 PM
  5. Broken Front Springs
    By gckimber in forum Superb
    Last Post: 26-05-2008, 09:25 PM
