Thread: Audi 80 tdi juddering bucking jerking
Page 20 of 30 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 293
  1. Re: Audi 80 tdi juddering bucking jerking
    Mar 2008
    Quote Originally Posted by hawkeye1975 View Post
    Hi Judders, not been on here for a while, okay, so have we finaly got a solution ?? my juddering is now accompanied by cutting out for a split second. When under load(ie going up a hill), you can feel it come off the boost just b4 cutting out. Just to add, my speedo occaisionally stops working, when this happens my Audi runs perfect, no judder or cut out.
    If this wire cutting works, can some one give me the idiots guide to doing it.
    Also, if cutting wires works, wouldn't it be a good idea to find out why it works ??
    Thanks in advance
    Peter
    It works!
    Lifes too short to worry why it works, just do it.
    Its on here what to do and it is idiot proof. Take a look back through this thread. Its posted and i followed the instructions took me 15 mins top! car has done 6k since and runs perfect. no warning lights nothing! better MPG as well as im not reving past the judder anymore.
    These cars are undoubtaly great but worthless in the real world because of there age and high miles so just do it.
    I promise you will not regret It
    cheers
    Ron
  2. Re: Audi 80 tdi juddering bucking jerking
    Aug 2007
    Cheers Ron, Will be unbolting my steering wheel (hopefully i've got a big enough socket!!) this afternoon, as long as the missus doesn't find MORE jobs for me to do !!
    Peter
  3. Re: Audi 80 tdi juddering bucking jerking
    Jun 2008
    Hi from New Zealand. We just bought a 1990 audi 80 20e.
    It judders under load from about 60 to 80 km/h and feels like a badly balanced tyre. It goes away when you coast taking the power off.
    Sometimes idles rough like its looking for fuel.
    I suspected inboard C.V. until I checked this forum.
    Can other judderers confirm the symptoms please.
  4. Re: Audi 80 tdi juddering bucking jerking
    Dec 2007
    8 Post(s)
    Quote Originally Posted by audi80nz View Post
    Hello NZ Lnder
    Is yours petrol model. if so there is another thread under
    Audi 80 2.0L ABK Engine Juddering/Misfire
    Problem with them seems to be weak soldered joints
    in a relay
    Diesels judder differently
  5. Re: Audi 80 tdi juddering bucking jerking
    Jun 2008
    Hi Michael. Thanks for the quick reply. Yes it is a petrol model. I'll switch threads to see what I can find out.
  6. Re: Audi 80 tdi juddering bucking jerking
    Jun 2008
    Hi. Turned out to be both inboard c.v.'s worn. All sorted now, couldn't wait for new parts from Germany so two good second hand drive shafts with c.v.'s fitted.
  7. Re: Audi 80 tdi juddering bucking jerking
    Jul 2008
    Hi, has any1 actually replaced all sensors? mine does the hunty judder dance and when i tried to hold my revs at a steady 1500rpm to flush the engine it was'nt having any of it! either dropping or increasing!!!
    Anyway, while having a few beers while giving it an oil change I slightly over filled it by a litre! tickover was spot on and it held the revs at 1500rpm no problem till i gave it a slight boot to 2200rpm at wich point I had a masive dump as the engine reved its ballbearings off due to oil in intercooler!!! after stripping all pipes and clearing excess oil its back to doing its jigg!!!
    i guess its just wornout or is it???
  8. Re: Audi 80 tdi juddering bucking jerking
    Jun 2007
    Gwent
    I'm not surprised it spat some oil into the intercooler with it being overfilled. I can't explain why the idle smoothed and the rpm held steady, due to the extra oil, or was it coincidence?
    Have you tried disconnecting the speed sensor wire?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  9. Re: Audi 80 tdi juddering bucking jerking
    Jul 2008
    Iv tried everything! all perishables have been replaced filters, pipes etc iv a feeling its a turbo related problem as it only seems to happen after the turbo kicks in, keeping rpm below 1800-2000rpm seems fine if your driving miss daisy! its as if its not breathing and getting clogged! could a blocked cat cause this? if the egr and inlet have gunged up does this not create cat blocking soot and the italian tune that some recomend just creates more soot, so when the turbo kicks in this just creates to much back preasure! i really havent a clue as this is my 1st audi and the only diesel engine iv ever had a problem with! might just remove cat as i cant see any sensors in on or around it! and according to my local exhaust centre cats serve no perpose on diesels anyway.
  10. Re: Audi 80 tdi juddering bucking jerking
    Jun 2007
    Gwent
    I decatted my passat tdi, due to low mpg's and lack of performance. It did not improve either of these by much, but the car revved more freely at the top end and the turbo produces boost earlier. This last point might make your problem worse?
    I agree the cat is not necessary for passing emissions, but it is there for a reason.
    I would have thought the air pressure sensors would 'tell' the ecu if the inlet is overpressurised, the boost control valve should then operate the wastegate to slow the turbo down.
    In other words, the management should be capable of looking after the boost level? If you get it scanned for fault codes it might tell you if a sensor has failed?
    If the intake is gunged up, it is well worthwhile clearing this out, the difference this made for me was most welcome.
    Have you read all of this thread? Most juddering problems seem to be reduced by disconnecting the vehicle speed sensor ( which is next to the CV joint on the gearbox) if this works there is a certain wire which can be cut that achieves a similar end but without losing the speedo function.
    The proper cure for the juddering problem seems to be stripping down and cleaning the diesel pump which looks to be a very specialised job, involving desoldering the electrical side of the pump control.
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  3. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  4. vw golf cutting out/jerking problem
    By vwgirl in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-03-2007, 11:58 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
