Thread: Audi 80 tdi juddering bucking jerking
Page 18 of 30 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 293
  1. Re: Audi 80 tdi juddering bucking jerking
    Mar 2007
    Did anyone tryed this solution until now? I'm really curious to see if it works. I have a friend whow has the same problem but he can only try this solution at the end of next week.
    Thank you
  2. Re: Audi 80 tdi juddering bucking jerking
    Good afternoom fellow judderers!!
    Im the proud owner of a 92 Tdi Avant. At only 98k
    The car has this prob, the one that you all seem to have as well!! There is a sensor at the top of one of the injectors, if you follow the cable it goes to a brown plug near the bulkhead. I unplugged this while the car was running and the engine cutout. Now it wont start at all so i cant try this 'fuse 12' or the VSS trick.
    Anyone know why it wont start anymore??
  3. Re: Audi 80 tdi juddering bucking jerking
    Well ive found the prob - its the knock sensor!
    Plugged in, runs like a bag of spanners. Unplugged then plugged back in, runs a dream!!
  4. Re: Audi 80 tdi juddering bucking jerking
    Cheers for your reply
    however i went to a diesel specialist and he was very aware of the problem. Electrical fault was the main cause. He rpaired the fault and now the car is running the way it should be. Thanks for your input.
  5. Re: Audi 80 tdi juddering bucking jerking
    what was this electrical fault??
  6. Re: Audi 80 tdi juddering bucking jerking
    Mar 2008
    Quote Originally Posted by fastmk1 View Post
    So come on tell us what you did. you unplugged something and your car would not start again, then you say you unplugged the knock sensor and replugged it and all is well. Please tell us exacty what you did. If this is the cure then share it with everyone. you where willing to ask for help here, so share with us what you did and what we need to do, step by step please. Its only easy if you know how.
  7. Re: Audi 80 tdi juddering bucking jerking
    Mar 2008
    Quote Originally Posted by jazziz View Post
    Are you actually going to share this information, or just tell your car is now running fine and leave?
    COME ON TELL US HOW IT WAS CURED!
  8. Re: Audi 80 tdi juddering bucking jerking
    gonna cost you.....
    Actually it isnt a knock sensor, its the Speed Sensor. tut tut!! Apparently euro car parts do them for 25 quid, so im gonna get one asap.
    All i did was have the engine running, unplug the grey plug in the middle of the bulkhead next to the fuel filter and see what happens to the running condition!! If it goes worse then its not it, if it improves then hopefully bingo!!!
  9. Re: Audi 80 tdi juddering bucking jerking
    right ive taken the sensor out, its the one behind the oil filter? speed sensor or knock sensor??
    anyways, i put a multi meter to it. Pass a magnetic object upto it and get no continuity so i think its busted fingers crossed.
  10. Re: Audi 80 tdi juddering bucking jerking
    yorkshire coast
    hi there all you judderers I disconnected the blue wire behind the dash as mentioned in this thread i`ve done about 5,000 miles since then and have suffered no ill effects, mpg are still good 40+ no lights flashin on dash etc. the juddering has gone just a little jerkey if your rough with the accelerator.
    Just thought i`d mention it incase any one was wonderin if the mod would cause long term damage but so far so good, i will post if there a problem but i cant see it happenin.
    I do still have hunting on idle though sounds like a tank, if you press the accelerator slightly and raise the tickover too 1000rpm the hunting goes away its always been like this even before i cut the cable behind the dash, if you increase the tickover with vag-com the hunting is still there, strange, i was wonderin if any one has tried adjusting the smooth idle mixture on vag-com to eliminate this problem as my version wont allow me to do it. i have already checked the fuel lines and there`s no sign of air getting in and apart from this the car drives fine. any help or inspiration would be greatly appreciated,
    my audi is a 1994 80 saloon with the 1z 1.9 tdi engine its done 185,000 miles now and still goes very well, sailed through last mot.
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  3. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  4. vw golf cutting out/jerking problem
    By vwgirl in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-03-2007, 11:58 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
