Thread: White stuff on oil cap
Results 1 to 8 of 8
  1. White stuff on oil cap
    Sep 2011
    Sheffield
    Hi, I've been getting quite a bit of white stuff on my oil cap, and I wanna know what is causing it.
    Before you say headgasket read the following..
    My car isn't loosing power, a mechanic says my radiator pipes are normal (the squeezing thing), my oil colour is normal, I'm not loosing water and there isn't a problem with my oil cooler housing as thats been tested also. There is never any white stuff on the dipstick, and no oil in my coolant. My car doesn't overheat either.
    What could be the problem? Is it the headgasket as I've been told several times it is and several times that it isn't.
    PS.. Golf MK4 1.6 8V 1998
  2. Re: White stuff on oil cap
    check the engine breather hose,it is also normal if you have many short trips and the engine does not reach 90deg,
  3. Re: White stuff on oil cap
    Oct 2009
    buckingham, buckinghamshire
    take the car on long drives...if you just pottering to work down the road or just to the shops its not getting warm enough to get rid of the condensation that forms in the engine....a dam good thrash every now n then will do it good....
    Audi A6 2.8 quattro avant.... as dead as a dead thing now
    now messing about in a mk4 2.0 golf gti..
    thats gone...now into an 03 passat 2.0 sport
  4. Re: White stuff on oil cap
    Dec 2007
    Belfast
    It sounds like you have water in your oil caused by condensation. When did she last have an oil change ?
  5. Re: White stuff on oil cap
    Sep 2011
    Croydon
    I had the same issue with my Bora and it turned out to be the short Journeys...
  6. Re: White stuff on oil cap
    Mar 2011
    Croydon UK
    Have the same thing on my Merc A140 - short journeys - engine not reaching optimal temp to burn off the condensation, take to car for a good run on the motorway now & again.
    Audi A4 B6 TDI 130
  7. Re: White stuff on oil cap
    Sep 2011
    Croydon
    Spot on Gavlar!!
  8. Re: White stuff on oil cap
    Feb 2014
    Manchester
    hi i got simula
  1. Please Help T4 cap on-white smoke cap off-fine
    By yellowcampervan in forum The Commercial Range
    Last Post: 10-06-2010, 10:22 PM
  2. Oil around oil filler cap
    By sanstorm999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2010, 09:19 PM
  3. creamy oil on oil cap, not on dipstick
    By haggis0073 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-09-2009, 12:57 PM
  4. Question Castrol Edge 507 5w 30 Oil Correct Stuff?
    By ax_box in forum Golf MK4 - 1999 - 2004
    Last Post: 06-10-2008, 11:33 PM
  5. Yellow foamy stuff on engine oil filler cap...
    By FroggleRock in forum Audi A3 - Archive Topics
    Last Post: 26-01-2007, 09:37 PM
