Thread: overboosting
  1. overboosting
    Aug 2011
    inverness
    my car has an overboost issue here the vagcom log any ideas??
  2. Re: overboosting
    134 Post(s)
    2009 Post(s)
    Let’s see a graph for Measuring Blocks 008, Group 011 display zones 02 and 03 but from you posted results the MAP sensor is stuck on 2539.8mBar and needs replacing.
  3. Re: overboosting
    Aug 2011
    inverness
    Thanks crasher i only have the unreg vagcom and cant get the graph bit working, I understand the measuring block but not group 11 zones 02 and 03??
    I take you mean the mass air flow MAF sensor?
  4. Re: overboosting
    Aug 2011
    inverness
    I took the MAP sensor out and sprayed it with brake cleaner and got turbo boost for a few mins!
    What i would like to know now is is the fault because there is too much oil in the intercooler system ? (if so how does it get there? ) or is it the sensor that needs replaced?
  5. Re: overboosting
    134 Post(s)
    2009 Post(s)
    You can’t stop some oil getting there; it comes from the breather and the turbo and is how it should be. Try a new MAP (Thrust) sensor.
  6. Re: overboosting
    Aug 2011
    inverness
    I got a second hand MAP sensor off ebay, and that seems to have helped alot, just need to give it a blast up the dual carriage way to see how it preforms . Thanks Crasher
  1. Please Help sharan overboosting
    By sharan888 in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2011, 03:57 PM
  2. What is overboosting?
    By twign in forum Golf MK4 - 1999 - 2004
    Last Post: 06-06-2008, 03:34 PM
  3. 2.5tdi overboosting ?
    By nokiamutt in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-04-2008, 01:13 PM
  4. K03 Overboosting?
    By CaneyJ in forum Golf MK3 - 1993 - 1999
    Last Post: 21-11-2007, 12:57 AM
  5. Overboosting
    By VEEDUBYA in forum Archive posts
    Last Post: 24-03-2007, 10:55 AM
