Thread: Suspension Overhaul
  1. Suspension Overhaul
    Jun 2010
    Ireland
    Buying a kit to replace the front suspension (control arms, TREs, sway link etc.) I'm wondering is there anything else I should be replacing I don't want to spend much money but dont want to half do the job either.
    I was thinking new shock will make a big difference all round but not sure if springs will. Is it worth buying new springs what effect will this have on the handling.
    I will be replacing the sway bar links but does the sway bar need to be replaced. Again im wondering what effect this will have on the handling.
    Do I need to do anything to the rear suspension?
    forgot to mention its a 01 AWX B5.5 FWD
  2. Re: Suspension Overhaul
    Jun 2006
    UK, Mids
    I would replace the dampers, but just inspect the springs for excess rust (which can make them snap).
    You could do CV boots if they look old.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Suspension Overhaul
    Jun 2010
    Ireland
    Do they contribute much to the feel of the suspension? I don't want to go to the trouble of replacing nearly everything else and not doing them but as with most people I'm on a budget and don't want to waste money where it's not necessary.
    Wheel bearings: Front: £24.50 Vetech £36.50 SNR
    Rear: £66.00 SKF
    Track arms: Lower Front: £61.50 Lemforder
    Lower Rear: £66.00 Lemforder
    Upper Front: £39.00 Lemforder
    Upper Rear: £42.50 Lemforder
    Tie rod: Inner: £18.50 Lemforder
    Outer: £23.50 Lemforder
    Anti roll bar link: £17.45 Lemforder
    Rear hub bushes: £34.50 Lemforder
    Shock Abs: Front: £39.50 Boge
    Rear: £39.50 Boge
    Coil springs: Front: £38.40 Lesjofors
    Rear: £34.00 Lesjofors
    This is what I'm looking at at the moment can anyone comment on the manufactures I know lemforder are quaility parts but not sure about the rest I have heard of boge. Is there anything else you would add. Do these prices look ok or does anyone know of a kit that would come in cheaper however I have at least a 20% discount on the above parts and no other costs on top.
  4. Re: Suspension Overhaul
    Rugby, Warwickshire
    Quote Originally Posted by Peter_HMR View Post
    Rear: £66.00 SKF
    Rear: £39.50 Boge
    Just one point, don't use the Vetech wheel bearings, they won't last long. Replaced both of mine with these and ended up doing them again after 12-18 months. Get SKF or OEM ones, it'll save you money in the long run.
  1. Bosch vp44 - recommendations for overhaul/replacment
    By The Fiend in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-10-2009, 06:49 PM
  2. Question Top Overhaul
    By ron_dave in forum Golf MK2 - 1984 - 1992
    Last Post: 08-02-2009, 11:41 PM
  3. Please Help ..smoking after engine overhaul
    By bwai in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-12-2008, 10:06 AM
  4. Suspension overhaul (phase one)
    By Boraman in forum Archive posts
    Last Post: 14-05-2007, 10:31 PM
  5. Turbo overhaul
    By jamesmc1 in forum Passat - Archive Topics
    Last Post: 04-01-2007, 08:41 PM
