Hi there,can anyone help me with these fault codes and what it will take to put them right.
Thanks.
Tuesday,30,August,2011,10:08:10:44707
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ7D016999 Mileage: 80940km/50293miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 7L0 907 401 B HW:
Component: 3.0L V6TDI G000AG 0080
Revision: --H03--- Serial number: VWZ3Z0F1513392
Coding: 0011779
Shop #: WSC 00395 941 75698
VCID: 2A50FF5FFC6F
No fault code found.
Readiness: 0 0 0 X 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 EB
Component: AL 750 6A 0879
Coding: 0004200
Shop #: WSC 31414 790 00001
VCID: 72E0273F143F
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
VCID: 3D7AC4031DE1
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 HW: 5WK 484 94
Component: Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F1513392
Coding: 0000232
VCID: E6C8CB6FA8F7
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 043 L
Component: CLIMA/AC 0721
Shop #: WSC 00000 000 00000
VCID: 3C7CC90706FB
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
02508 - Temperature Sensor for Refrigerant (G454)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
Part No: 7L6 937 049 M
Component: 3003
Coding: 0065636
VCID: 4688ABEF4837
1 Fault Found:
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 F
Component: 0G Airbag 8.4E+ H11 1151
Coding: 0012359
VCID: 26480B6FE877
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010031
VCID: 448CB1E77E0B
Address 17: Instruments Labels: 7L6-920-xxx-17-7LA.lbl
Part No: 7L6 920 871 K
Component: KOMBIINSTRUMENT RB8 2111
Coding: 0007111
VCID: 3F86BE0B17ED
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000000
VCID: 336EE23B2BA5
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0E4AD379A33
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 458AACE37531
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 8D1AD4C3EDC1
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 H
Component: YP HSG 0400
Coding: 0000065
Shop #: WSC 00235 941 98775
VCID: 4182B8F36119
Part No: 7L0 959 701 K
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 K
Component: Tuersteuergeraet BF 0201
Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0201
Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 7L6 035 195 A
Component: Radio DE2 0012
Coding: 0000401
VCID: 3162E833D1B9
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 L
Component: Front Wiper 4027
Coding: 0000336
Shop #: WSC 31414 790 376833
VCID: 3D7AC4031DE1
Component: RLS nicht vorhanden
Coding: 00000000
Shop #: WSC 00000
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
VCID: 4894A5D74223
