Thread: Wiper Stalk Wiring
  1. Wiper Stalk Wiring
    Aug 2011
    Witney, Oxfordshire
    Does anyone have the wiring diagram for the wiper stalk, I'm interested in the wiring to the two buttons on the stalk that are used to cycle the centre display between Miles to empty > MPG > etc, etc.
    I just need to know what pins the wires from these switches go to in the connector.
    Rod
  2. Re: Wiper Stalk Wiring
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by RodA View Post
    Rod
    Just looked in haynes manual and it only states the wiring of the stalk goes to the canbus system doesnt state the logical switches and pin outs unfortunatly. If your car doesnt have the stalk then surely the stalk plug will be the same but with 6 pins missing? two for up/down and reset? Then its hit and hope...
  3. Re: Wiper Stalk Wiring
    Aug 2011
    Witney, Oxfordshire
    I was hoping to find someone who had replaced the stalk and knew the actual pin connections. Yes I could guess the 'spare' pins but not knowing what's actually on the them in terms of ground or voltage I feel it would be a bis risky.
    Rod
  4. Re: Wiper Stalk Wiring
    Near Blackpool
    48 Post(s)
    Surely if your replacing the stalk then a like for like swop would just be plug and play?
  5. Re: Wiper Stalk Wiring
    Aug 2011
    Witney, Oxfordshire
    No I'm not replacing the stalk, I've activated the 'Miles to empty' with Vag-Com but can't cycle through the options because I don't have the switches on my stalk.
    I thought if I could find out the switch connections I could mount two new switches somewhere on the dash to mimic the stalk switches.
    Rod
  1. Mk 3 Wiper stalk problem
    By baby-mechanic in forum Golf MK3 - 1993 - 1999
    Last Post: 07-09-2010, 04:37 PM
  2. wiper stalk replacement???
    By jperkie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2010, 12:02 PM
  3. Question wiper stalk
    By richvw2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2009, 09:35 PM
  4. Please Help Wiper Stalk Stuck
    By emphyze in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2008, 05:22 PM
  5. Problem with Wiper Stalk
    By paul&paulaspassat in forum Passat - Archive Topics
    Last Post: 13-02-2007, 02:13 PM
