Hi all.
Long story short: Bought private and only noticed problems on way home. I noticed because my previous car was a Skoda Superb with the same engine: a 1.9TDI PD130 AWX.
Symptoms:
1. Throttle hesitation - press it and engine takes about a second to respond.
2. Low power - feels like 90bhp.
3. Bad MPG - I get 38-42mpg average on a 50 mile journey that I normally got 50mpg.
Observations:
4. Got it checked on VCDS - no codes.
5. Disconnected MAF, performance was worse.
6. Exhaust is Smokey (like after being started from cold) - expected overfuelling.
Vacuum System: (this is the interesting bit)
7. I attached a clean tube to the EGR valve and sucked hard, nothing budged. With engine on, any blip in the throttle results in the valve making a farting noise. I don't know if it's actually working.
8. The anti-shutter valve is NOT working.
9. VNT actuator operates on engine start but doesn't move unless given a lot of throttle.
My own VCDS-Lite (unregistered at present):
10. Still no faults.
11. Engine warm, dash says coolant is 90°C but VCDS says it's 79.2°C. This could be the source of the bad mpg problem...
12. ...er, have to register VCDS Lite to scan for faults
13. Injector quantities all within +/- 0.5mg/hr at idle. Nothing to suggest worn cam lobes.
Anyone else come across similar problems before? 03 Passat B5.5 1.9TDI PD130 AWX 120K miles.
Thanks in advance
