Thread: How to remove bottom insert on 3 spoke mfsw sport steering wheel ?
  1. How to remove bottom insert on 3 spoke mfsw sport steering wheel ?
    DAVE NIC Guest
    Hi.
    I would like to remove the bottom spoke black insert on my '57 Sport Passat's MFSW to replace it with one of the aluminium versions found on other VW's with the same steering wheel. I have gently tried to prise it off with my fingers but it does not seem to want to easily come off. I am cautious about applying too much force in case I break it or another part of the steering wheel behind it. Can anyone please supply me with some advice on how to safely remove the insert ? Cheers.
  2. Re: How to remove bottom insert on 3 spoke mfsw sport steering wheel ?
    Jan 2010
    Lisburn, United Kingdom
    Just pull! It's plastic into rubber so you can't really break it. The new piece with just push in.
  3. Re: How to remove bottom insert on 3 spoke mfsw sport steering wheel ?
    DAVE NIC Guest
    Thanks for the advice - a pull I will give it then ! Cheers.
  1. Question Flat bottom milti function steering wheel
    By JayA3sline in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-08-2014, 10:37 AM
  2. Question Will a 3 spoke 's-line/sport' steering wheel fit?
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2011, 10:43 PM
  3. Can I swap MFSW for flat bottom MFSW
    By Two_Stripes in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-05-2011, 10:20 PM
  4. Multi functional steering wheel insert removal
    By bf47 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-02-2010, 08:31 PM
  5. Golf MK5 MFSW (multi function steering wheel) re-programming ?
    By shaft-50 in forum VCDS - Help Requests
    Last Post: 09-09-2009, 05:15 PM
