Thread: Given oil pump, injectors & DPF issues - What year 2.0tdi is the least risky??
  1. Given oil pump, injectors & DPF issues - What year 2.0tdi is the least risky??
    Aug 2011
    Ireland
    I'm looking into buying a B7 2.0tdi avant and came across this forum. I have to say I'm shocked at the nature of the mechanic faults and amazed at AUDI stance to concerned customers.
    I've been a long time fan of the VAG cars and I had my heart set on a 2005 B7, but with the chain driven oil pump system used I decided to avoid that year. Then I find out about the 2006 injector failures and the hex drive problems on the gear driven pump!
    Has AUDI designed out these problems on the later 2.0tdi engines? Is a 57 plate 2.0tdi guaranteed to have double sealed injector, gear driven oil pump with longer hardened hex shafts and concentric balancer shafts?
    Or should I just focus on trying to find a good 1.9tdi B7?
    It's a shame to see such a good car ruined by poor design and development.
    Seán.
  2. Re: Given oil pump, injectors & DPF issues - What year 2.0tdi is the least risky??
    Aug 2011
    Ireland
    After a lot of reading, I reckon I'll start looking for a good B6 instead!
  1. Thinking of buying a 2.0TDi, oil pump advice
    By bryanp in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2011, 12:56 AM
  2. 2.0tdi Oil pump chain failure
    By Blue Smoke in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-08-2011, 04:53 PM
  3. Important DPF replacement 2 in 1 year.
    By workshop2011 in forum The Commercial Range
    Last Post: 03-02-2011, 06:55 PM
  4. what year was dpf introduced?
    By dannn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2011, 07:43 PM
  5. Attention 2.0 TDI Oil Pump/Balance Shaft Issues
    By Jack Ford in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-01-2010, 11:37 AM
