Thread: dpf stinks
Results 1 to 10 of 13
  1. dpf stinks
    hi all
    can anyone shed any light on why my exhaust fumes are so bad, its been like this about a year now, theres no smoke and no lights on the dash, i have looked at the lamba readings on mb075 using vcds and it shows 27%. is it possible my lamba sensor is knackered and the dpf is blocked?
    if you put your face in front of the exhaust it makes your eyes sting and water, and you can smell the fumes if stopped at the lights with window down.
    its the 170 bmr engine
    could it be turbo related, i ask this as i had a failed oil pump last year and never replaced the turbo as it seemed ok, the car still drives ok, i replaced the tandem pump a few months ago due to finding the fuel in the filter housing to be black, i have a feeling that the fuel is black again as i am getting the same misfire when i floor it again, which was the reason for checking the fuel in the first place, so i have either got another knackered tandem pump or the injector seals have gone.
    hope this makes sense and that someone can put all this together and make a diagnosis
    many thanks
  2. Re: dpf stinks
    DSG4ME Guest
    What you describe is like the Cat Converters of yesteryear, sulphuric and rotten eggish?
    I would change gas station if you use the same one all the time as it sounds like it's neat fuel rather than played about with low sulphur additive ones to me.
    Car shouldn't worry you, this smell is indicative that the cat is working ok.
  3. Re: dpf stinks
    Nov 2010
    Rossendale
    Hi - Regarding the above. I also have the same problem, i.e. the car exhaust stinks enough to give you a headache. There are no lights or messages on the dash, I also took the car to a local garage and nothing came-up on the diagnostic machine either. Some advice that I was given was to put the expensive diesel (which I did) and to drive it hard on the motorway to clean the system (which I also did). The problem still exists, and especially when idling the smell is over-powering. I have also changed the oil and oil-filter as a precuation although the next service is due next year.
    Can anyone advice, as this surely cannot be normal.
    Hayat - Passat 56' 2.0tdi 170
  4. Re: dpf stinks
    Feb 2009
    Wakefield. W.Yorshire
    Mine is the same.. althought the changing fuel filter helped a little... very little..
    08 VW Passat 2.0 TDI 170 Sport (De-DPF'd - Remapped)
  5. Re: dpf stinks
    Nov 2010
    Rossendale
    Is there a solution? Can I get rid of the smell from the exhaust? And sometimes it can be very jerky when I set-off and have to rev it to smooth it out (running). No lights/messages on dash. There is no soot in the exhaust tailpipe either.
    Hayat Passat 56' 170 sport
  6. Re: dpf stinks
    Dec 2010
    Renfrewshire, Scotland
    Understand this is an old thread, but I'm noticing the fumes in the car are very strong. Often makes it into the cabin when at idle.
    No problems with the drivability of the car, new injectors and recently serviced. The technician at VW looked around the engine bay and couldn't see anything - has offered to put it on the ramp and check other areas.
    Other people are seeing the same? It's almost like the car is 15 years old and has enough miles covered to the moon and back.
  7. Re: dpf stinks
    DSG4ME Guest
    Quote Originally Posted by Hayat View Post
    You won't have cos you have a dpf as standard, this smell isn't the dpf anyway it's a catalytic converter that causes it, sometimes due to newness, fuel quality or a rich running engine with unburnt fuel getting down the pipe.
  1. Air Con stinks of smelly socks?
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2011, 10:52 PM
  2. Help with DPF...
    By avidblue in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2010, 01:34 PM
  3. Dpf
    By Petemate in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-04-2010, 07:16 PM
  4. Dpf
    By Petemate in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-02-2010, 09:06 PM
  5. Dpf
    By podwin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-08-2008, 10:30 PM
