Thread: Electric Motor / Pump Noise
  1. Electric Motor / Pump Noise
    Apr 2010
    Ashford, Middlesex
    Over the last couple of weeks, when starting my 2.0PD Passat, I have heard quite a loud humming noise which sounds like a motor or a pump running. It doesn't do it every time, and seems as though it is more disposed to doing it after it has stood overnight or longer.
    It did it this morning, and when I heard it, I switched the air-con off (wondering if it might be the cooling fan or something), and then got out and had a listen - I think its actually coming from the boot area, which leads me to think that its the fuel pump?
    Are these:
    - Prone to failure
    - Likely to make similar noises when on the lead up to failure
    - Expensive
    - Hard to replace
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Electric Motor / Pump Noise
    Norfolk
    - Prone to failure.......Early ones were
    - Likely to make similar noises when on the lead up to failure......Noise likely to be sign of failure but can stay noisy for some time
    - Expensive.....About £200 plus fitting
    - Hard to replace.....Fairly easy
    If it were me I would ignore it and see if it gets louder or fails !!!!!
  3. Re: Electric Motor / Pump Noise
    Apr 2010
    Ashford, Middlesex
    Thanks Martin
    As I have full roadside recovery, and the problem is currently only intermittent, that is exactly what I shall do.
  1. Please Help wiper motor electric problem
    By tamerkamal in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2009, 12:57 PM
  2. Polo Mk 4 Electric window motor
    By fishy09 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-04-2009, 11:17 PM
  3. Question Electric window motor
    By CalmBSK in forum Golf MK3 - 1993 - 1999
    Last Post: 06-09-2008, 11:29 AM
  4. mk3 electric window motor
    By wheela33 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-08-2007, 03:45 PM
  5. Electric Window Motor
    By alperin in forum Early Passat Forum - Pre 97
    Last Post: 04-06-2007, 09:02 AM
