Thread: Misfire at 1200rpm
Results 1 to 10 of 20
  1. Misfire at 1200rpm
    Dec 2009
    united kingdom
    My 1.8 b5 passat seems slugish and unresponsive.When i pull away from a standing start i get a slight rumbling from the engine,also at speed if i take my foot of the gas she seems to give a kick.Small misfires from cold and generally not very nice to drive.Once up to temp if i hold the revs at 1200 she misfires and the revs go up and down continually,also driving down a hill no load on engine and at 1200 she seems to cangeroo when driving.If i drive her hard things get a little better ,seems like a fuel air intake prob to me.I live within the surrey area and would appreciate any help.
  2. Re: Misfire at 1200rpm
    Apr 2009
    Could be a lot of things, from coil-packs to engine speed-sensor.
    Need to start with a code-read
    Regards
    Jim
    Still Crazy After All These Gears
  3. Re: Misfire at 1200rpm
    Dec 2009
    united kingdom
    Thanks Yaman,
    May well invest in a reader with a view to buying another vw in the future but my faith in vw is diminishing.
  4. Re: Misfire at 1200rpm
    132 Post(s)
    1980 Post(s)
    Year and engine code?
  5. Re: Misfire at 1200rpm
    Dec 2009
    united kingdom
    Hi Crasher,
    The passat is a 1998 model, and an ADR engine.
    Regards,andy
  6. Re: Misfire at 1200rpm
    132 Post(s)
    1980 Post(s)
    Coil pack/lead issues are common on this engine.
  7. Re: Misfire at 1200rpm
    Dec 2009
    united kingdom
    Is there a fault code for coil/leads ?
    Can i just say this missfire only seems to be when the throttle is just slightly open.I'm a carb man myself and this just seems to point to air/mixture to me.When i start from cold you get small bumps and miss-fires and when it's warm just now and then.When the throttle is only just partially open the revs go up and down and missfires.
    I wish i could go to my local vw franchise but had too many bad experiences there.!!!
    A reputable garage near Camberley for a diagnosis would be great.
  8. Re: Misfire at 1200rpm
    132 Post(s)
    1980 Post(s)
    No the ADR will not recognise any HT circuit faults in the ECU’s diagnostics. I wonder if it is a broken inlet manifold flap actuator. Pop the cover off and check.
    Then check the arm
  9. Re: Misfire at 1200rpm
    Dec 2009
    united kingdom
    I know where you are coming from at this point,had a similar symptom a few years ago and the arm had broken,chuging and generally orible in traffic.Replaced at a dare i mention
    £136.00.I wish it were that simple.
  10. Re: Misfire at 1200rpm
    132 Post(s)
    1980 Post(s)
    So that arm is OK on your car now?
  1. No Accelerator pedal response - engine sits at 1200rpm
    By themuttons in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-05-2011, 11:49 AM
  2. Golf 4 1.6 1200rpm idle speed
    By VWGAndy in forum Golf MK4 - 1999 - 2004
    Last Post: 29-08-2009, 08:47 AM
  3. Golf mk2 16v gti misfire shudder misfire
    By paramananthamd in forum Golf MK2 - 1984 - 1992
    Last Post: 22-10-2008, 05:32 PM
  4. misfire@ 1200rpm golf mk4 tdi
    By rimk4gttdi in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2008, 07:06 PM
  5. Audi A3 - Uneven idling 400-1200rpm + cutting out!!
    By spudmanpete in forum Audi A3 - Archive Topics
    Last Post: 15-07-2007, 11:38 PM
