Thread: what bluetooth handsfree
  1. what bluetooth handsfree
    Apr 2007
    London
    im looking at a bluetooth car kit for my car.
    im not sure whether to get a sony ericsson jobbie that you can mount on our visor, or a full blown parrot bluetooth jobbie that requires wiring up.
    is there any you would recommend. ideally i want something you can just mount on your sunvisor, but i do like the look of the parrot ones.
    any advise would be welcomed. thanks
  2. Re: what bluetooth handsfree
    7 Post(s)
    I've got a Jabra sunvisor jobby, cost £40 and most importantly stops you looking like a SPACE CADET with one things on ear-ole.
    Oh, it works really well as well.
  3. Re: what bluetooth handsfree
    Jul 2007
    hi blacksline
    I've have experience with the Jabra and the Parrot.
    They're both good items, but I do recommend the Parrot (I'm not sure which model I used)
    pros for the jabra:
    no messing
    portable
    cons for the jabra:
    dialing numbers
    having to charge it up (although you do get a cigarette lighter)
    remembering to put it in a safe position when finished
    remembering to switch it off when finished
    Pros for the Parrot:
    None of the cons for the jabra - easy access to phonebook, and always connected to the car.
    cons for the parrot:
    a little messing to install (although if you can install a headunit/radio, you can install a Parrot).
    HTH
    SM
  4. Re: what bluetooth handsfree
    Apr 2007
    London
    mmm
    thnks for replies, very helpful.
    i did like the look of a parrot in car bluetooth set...
    but wasnt sure how easy it is to wire in, i know its only a few wires, but how easy it is to open dashboard up?, or run the cables?
    thnks.
  5. Re: what bluetooth handsfree
    Jul 2007
    ah good point blacksline.
    I've only recently got my Audi, so I've never stripped it out.....I also don't like the thought of it either. It may possibly just a case of taking the headunit out....I'll see if I can find some more information.
    Hopefully someone else here may be of help.
  1. help on bluetooth preparation
    By frank in forum Passat - Archive Topics
    Last Post: 03-12-2007, 10:15 AM
  2. Audi A4 Bluetooth Kit
    By u37255 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-07-2007, 12:53 PM
  3. VW Bluetooth Kits
    By Pimped-Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-07-2007, 01:07 PM
  4. Bluetooth handsfree
    By kiwibeef in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2007, 06:43 PM
  5. Fitting nokia CK 7W handsfree to A4
    By glen4 in forum Audi A4 - Archive Topics
    Last Post: 09-03-2007, 08:41 PM
