Thread: Aircon High Pressure Switch Replacement
Results 11 to 20 of 25
  1. Re: Aircon High Pressure Switch Replacement
    Sep 2008
    chester
    17 Post(s)
    Jim if your fans not kicking in your compressors not functioning,you can check by observing the front plate on the pulley should spin with the pulley when the clutch is energised,by the way who did your regas?
  2. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    The compressor is definately not engaging. A local garage did the regas. I suppose next step is getting compressor changed, which means money. Could be the end of the A4...
  3. Re: Aircon High Pressure Switch Replacement
    Sep 2008
    chester
    17 Post(s)
    Check you've got voltage at the clutch when the aircons on,no voltage means the comps not being asked to start.
  4. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    If I look down from the front of the car, the compressor is on the left below the condensor fan? It's hard to see whats down there without removing a lot of stuff.
    I can't see any wires going to the compressor so I'll need to remove some of the pipes to get a voltage reader in.
    Is the compressor replacement job a front of car off job?
  5. Re: Aircon High Pressure Switch Replacement
    Sep 2008
    chester
    17 Post(s)
    No ,just jack the front up and take the undertray off.
  6. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Thanks. Assume that's the easiest way to check the voltage as well?
  7. Re: Aircon High Pressure Switch Replacement
    #17
    Sep 2008
    chester
    17 Post(s)
    Yes,before you condemn the comp,check the easy things first,if there's voltage there it could be the clutch inop,if no voltage run a fused line from the battery to it and see if it works(engine off)also talking about easy things have you checked the fuse,do a continuity check across the blades, not visual!also check inside the fuse holder make sure some ham fisted git hasn't bent anything.
  8. Re: Aircon High Pressure Switch Replacement
    #18
    Mar 2009
    First thing I did was check the fuses -1 and 6 I think are AC fuses. They looked fine. I then got the regas done which showed no leaks are pressure problems. Next was VAGCOM showing the high pressure switch dead, so I replaced that and the error cleared.
    That's where I am. I'll prob have to let and indie garage have a look.
  9. Re: Aircon High Pressure Switch Replacement
    #19
    Oct 2010
    Middx, UK
    The compressor is basically a mechanical devise so there's not much to 'go wrong' as such. I've just bought new clutch for mine, which is premetive as i havent even checked power to it yet!..You're doing the right things though and nce you can establish power to the compressor is ok, the next step is to check that the clutch is not slipping or the front plate is not loose.
    I took mine to a local indie garage and they were charging around £500 to replace the compressor, which is a bit out of my budget tbh.
    A4 B6 S-line, 90k miles
  10. Re: Aircon High Pressure Switch Replacement
    #20
    Mar 2009
    I've had quotes much the same. I have found a place that supply second hand compressors for £105 delivered with 90 days warranty. Prior to that, I am going to pop the engine cover off the bottom and just check the clutch - maybe it's something simple like the plate has fallen off. Probably not, but worth a look.
    Few quotes so far to fit replacement compressor and regas £150 ish which would mean around £250 all in. Quite annoying if truth be told, as this is one of those jobs where I guess you really need an aircon gaser, which I don't have !!
  1. Replies: 9
    Last Post: 18-07-2011, 10:21 PM
  2. Aircon high pressure
    By instrutec in forum A8 - S8 - V8
    Last Post: 04-06-2010, 12:32 AM
  3. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
  4. Where is the aircon "high pressure sensor" on a 2002 A4?
    By pds999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2008, 10:58 AM
  5. Bora Aircon Switches Off On High
    By sandhamm in forum Bora - 1998 - 2005
    Last Post: 13-05-2007, 12:36 AM
