Thread: Aircon High Pressure Switch Replacement
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Aircon High Pressure Switch Replacement
    Mar 2009
    Hi all. Recently chopped a Passat 2004 in for an Audi A4 B6 1.9 Tdi 130. VAGCOM tells me the aircon switch is dud.
    Regards replacement - do you have to drain down the aircon system prior to replacing it? I have been searching around and some say there is a valve that allows a simple replacement and some say the gas will escape.
    Can you do this without removing the headlight or bumper?
    Thanks,
  2. Re: Aircon High Pressure Switch Replacement
    Dec 2006
    You can remove it without removing the headlight..
    Just get a spanner on it and turn it half a turn at a time.
    The sensor sits on a Schrader valve (same as your car tyres) so no gas (hardly any) escapes.
    Rick
  3. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Thanks for the quick reply. So is it as easy to get the new one in as it is to get the old one out if the headlight is still in place?
    £44 from TPS - that sound about right? I'm having trouble getting the part number for the exact one, so to compare prices.
    Had the regas yesterday and the service showed no leaks etc, so I'm praying that it is this sensor as VAGCOM says and not something worse.
  4. Re: Aircon High Pressure Switch Replacement
    Dec 2006
    Quote Originally Posted by jim_tdi View Post
    Its been around 3 years since I did it... (and im not 100% sure now thinking about it if you do have to remove it..)
    But its only 4 torxs to undo if to remove the headligght.. 2 at the front and 2 at the back.. but dont remove the torxs from the rear, undo them around 8 turns and you can slide ethe headlight out with them in place.. (It makes it easier for when you put the headlight back in)
    In regards to the part..Give Jason a call at All German Parts - He's a forum sponsor and also mention I sent you.
    All German Parts Limited
    16 Pontefract Road
    Leeds
    West Yorkshire
    LS10 1TB
    United Kingdom
    Telephone: 0113 2775245
    Rick
  5. Re: Aircon High Pressure Switch Replacement
    Dec 2006
    See this thread for removing headlight.
    https://www.vwaudiforum.co.uk/forum/s...E-NOW-UPLOADED
  6. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Thanks for that. I have ordered from Jason.
  7. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Unfortunately the one from Jason was the wrong one, but I sourced another one and it has cleared the fault codes on VAGCOM.
    Unfortunately there is still no cold air. The economy button does not come on automatically now, so I am fairly sure that the high pressure switch did have a fault and is now ok. However, there must be something further wrong, and that must either be the condenser or the compressor?
    Quite frustrating...I was hoping that the switch was the issue.
  8. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Further investigation; the condenser fan does not run at all. I guess that this is either the cause of the fault, or something is causing that not to run.
    I unplugged the condenser power plug. There is a red wire and a purple wire going into the plug. Looks ok. There is also a corroded black wire that is cut off inside the wire sleeve. Should there be three or two?
    Thanks.
  9. Re: Aircon High Pressure Switch Replacement
    Mar 2011
    mansfield, uk
    Has the system been regassed?
  10. Re: Aircon High Pressure Switch Replacement
    Mar 2009
    Yes it has.
  1. Replies: 9
    Last Post: 18-07-2011, 10:21 PM
  2. Aircon high pressure
    By instrutec in forum A8 - S8 - V8
    Last Post: 04-06-2010, 12:32 AM
  3. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
  4. Where is the aircon "high pressure sensor" on a 2002 A4?
    By pds999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2008, 10:58 AM
  5. Bora Aircon Switches Off On High
    By sandhamm in forum Bora - 1998 - 2005
    Last Post: 13-05-2007, 12:36 AM
