Thread: Polo 1.4 16v APE engine noise
  1. Polo 1.4 16v APE engine noise
    Jul 2009
    Fillongley England
    My engine [petrol] has started to vibrate and is noisy above 3000 rpm. Seems to be at the top near the belts end, stationary or driving. Removed belt cover and belts and tensions are fine. [belts 5000 miles old] Nothing external loose. Oil/filter change did not help. How could I check if the cam/ hyd lifters are working correctly? engine power and fuel consumption seem normal. This car has always had a rattly cam sound on cold start/idle, but the above is new and I wish to fix myslef if possible. 60,000 slow miles!! no warning lights showing.
    Please advise.
  2. Re: Polo 1.4 16v APE engine noise
    Jul 2011
    Weymouth
    Hi, only way to check is to remove the rocker cover
  3. Re: Polo 1.4 16v APE engine noise
    Jul 2009
    Fillongley England
    Found some useful clips on youtube, as well . Will open up engine after hols.
  1. Polo 1.4 16v engine light and rough running
    By AJB in forum Polo - Derby - Lupo - Fox
    Last Post: 17-10-2014, 08:13 PM
  2. VW POLO 1.4 16V (75bhp) Vag will not read engine
    By boilerchicken in forum VCDS - Help Requests
    Last Post: 27-01-2009, 11:22 AM
  3. 2003 Polo 1.4 16v (75) ticking noise???
    By robsgti1 in forum Polo - Derby - Lupo - Fox
    Last Post: 14-10-2008, 02:17 PM
  4. EPC and Engine Light Fault 2003 Polo 16v
    By iggy28 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2008, 03:22 PM
  5. Polo/Lupo 1.4 16V engine code
    By stevehop in forum Polo - Derby - Lupo - Fox
    Last Post: 29-03-2007, 05:58 PM
