Thread: Oil in water, 1993 2.0 16v coupe
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. cutting out when hot, 1993 2.0 16v coupe
    Jun 2011
    Northampton
    Hi I bought a 93 coupe that had been stood for 4 years checked everthing I could got it and got it running to take for an mot, got 10 miles down the road and the engine note changed and oil light flikkered on so I stopped immediately, no oil on the dip stick but loads of sludge in the expansion tank, it was all fine before I set off. The car went into my mates garage and had a new head gasket fitted and the head checked and they warmed the car up and everything was fine, but on my way home exactly the same thing happened as before the oil was pushed into the expansion tank. Just wondered what else could have gone wrong?
    Is the block gone or does the ace engine have a water cooled oil cooler that could have gone?
    Any help appriciated.
    Cheers stu
    Oct 2010
    Here And There
    I have had problems with various engines like this over my years of mechanicing. Replaced head gasket and got head skimmed, pressure tested and x rayed ( did you get it checked or just skimmed ? ) .... same problem, everyone assumes the block. I have my suspisionsthat the heads are not checked properly. I would recommend a new plant for her ( engine )
  3. Re: Oil in water, 1993 2.0 16v coupe
    replace the oil cooler
  4. Re: Oil in water, 1993 2.0 16v coupe
    Gwent
    If it helps, it's the part that the oil filter seals to.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
    Oct 2010
    Here And There
    Or not
  6. Re: Oil in water, 1993 2.0 16v coupe
    134 Post(s)
    2013 Post(s)
    Quote Originally Posted by kenney View Post
    x2
  7. Re: Oil in water, 1993 2.0 16v coupe
    Jun 2011
    Northampton
    I paid to have the head pressure tested and skimmed, will be having a look at the oil cooler sometime during the week after work.
    Cheers for the help guys, stu
  8. Re: Oil in water, 1993 2.0 16v coupe
    134 Post(s)
    2013 Post(s)
    You had the head removed due to oil in the water before replacing the oil cooler! In the vast majority of cases, oil in the water can only come from a failed oil cooler. Water in the oil would be a head gasket, not oil in the water.
  9. Re: Oil in water, 1993 2.0 16v coupe
    Jun 2011
    Northampton
    Yes crasher, didn't know anything about the oil cooler and the car was booked into my mates for the cam belt to be replaced so asked them to do the gasket at the same time. Had exactly the same problem with oil in the water on my 325i sport and it was a cracked head so just assumed it was the same problem on the Audi. I know now that oil pressure light and no rev counter is an alternator problem and brake fluid light is power steering pump, now know oil in water is oil cooler, never mind you live and learn.
    Stu
  10. Re: Oil in water, 1993 2.0 16v coupe
    Sep 2011
    Worcester
    Quick reply to this thread I've got an Audi coupe same age which has sat for a while also... There is oil in the water which was suspected head gasket but with a bit of research I have concluded the oil cooler is at fault.
    But it's having trouble with start up now and sounds like it's misfiring on start up like theres water in the cylinder... Could this be down to the oil cooler or a faulty coil pack
    It's also using alot of oil.... Oil cooler?
    Rob
  1. Please Help coupe aux belt replacement 1993 2L 16v
    By keo-the-dog in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 28-12-2010, 03:46 PM
  2. Audi Coupe 2ltr 16v (ACE) 1993 - Engine quiz :)
    By FSARoyster in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-08-2010, 09:01 PM
  3. Wanted - Water and PAS support bracket - 80 Coupe 16v ACE (1993)
    Last Post: 27-07-2010, 11:13 AM
  4. Upgrade or nonsense? 1993 80 2.0 16v
    By FlyingDutchman in forum 80 - 90
    Last Post: 06-07-2009, 11:18 AM
  5. Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    By Emgee in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-02-2009, 11:26 PM
