Thread: engine management light on after egr block
  1. Unhappy engine management light on after egr block
    teddy2k5 Guest
    Hi i did somethink silly and blocked of my ERG pipe with a can of coke cut out thinking thats how you do it and now i have a engine management light on so i took it off and i still have the light so am guessing it needs to be reset or will it clear on its own did nothink els just blocked the egr pipe off
  2. Re: engine management light on after egr block
    You will need to reset it or clear fault code.
  3. Re: engine management light on after egr block
    134 Post(s)
    2004 Post(s)
    It will keep coming back on unless the ECU is modified, just reinstate the EGR and leave it alone.
  4. Re: engine management light on after egr block
    teddy2k5 Guest
    did do mate light gone off thanks guys
  5. Re: engine management light on after egr block
    May 2008
    Finland
    The code will come back.
    You need to drill a 6-10mm hole in the center of your blocking plate to keep the codes away, or get your ECU flashed with a software that deletes the EGR.
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  1. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  2. A4 Engine Management Light
    By EBO13 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2008, 07:11 AM
  3. engine management light
    By audi-nutz in forum Audi A4 - Archive Topics
    Last Post: 23-01-2008, 08:55 PM
  4. A2 engine management light
    By guntrip in forum Chat - Anything with wheels
    Last Post: 23-08-2007, 04:10 PM
  5. engine management light
    By johnnynonails in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 04:02 PM
