Thread: GTTDI 130 2002 ASZ, Problems with temp guage, help please! coolant sensor faulty possibly????
  1. GTTDI 130 2002 ASZ, Problems with temp guage, help please! coolant sensor faulty possibly????
    Jan 2008
    I've had my golf 2 days and am having problems already. Yesterday the glow plug light stayed on for about 5-8 seconds then when the light went out and i started it, it revved up to about 1500 rpm. Drove to work this morning all ok, drove home and the temp guage started moving then dropped down to nothing and the tried to move again and then stopped again as if the engine were stone cold.
    I'm concerned as you can imagine. Could it be the coolant temp sensor as my MPG seems all over the place as well and i'm worried the car is duff and i've only had it 2 days.
    Please help anyone??
  2. Re: GTTDI 130 2002 ASZ, Problems with temp guage, help please! coolant sensor faulty possibly????
    Southampton, UK.
    The Coolant Temperature Sender would be my first suspect as this can have a big impact on MPG and starting. A genuine VW one (green) costs about £22 from the dealer. A fault code read would probably throw something up. Worth doing anyway as you can check what the temperature is that the sender is sending to the ECU.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  3. Re: GTTDI 130 2002 ASZ, Problems with temp guage, help please! coolant sensor faulty possibly????
    Jan 2008
    Have fitted a new sensor and all is back to normal again, until the Check coolant light came on today so i guess i need to top up a bit more. What is the correct procedure for topping up antifreeze??
  4. Re: GTTDI 130 2002 ASZ, Problems with temp guage, help please! coolant sensor faulty possibly????
    Southampton, UK.
    I think it's neat G12+ straight into the expansion tank.
  1. Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    By graemer147 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-10-2013, 11:56 AM
  2. Please Help Temp guage / fuel guage faulty on Mk4 Golf 1.9 sdi
    By Christighe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-06-2011, 10:45 AM
  3. Faulty coolant temp sensor?
    By jb1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2009, 01:21 PM
  4. 1.9 TDI 130 faulty temp sensor?
    By Luker2006 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2008, 08:03 PM
  5. '03 Ibiza 1.4 16v - faulty coolant temp sensor
    By Sam in forum Ibiza - Cordoba
    Last Post: 06-11-2007, 02:37 PM
