Thread: Audi A6 (2006) European "Tourist Mode" - help needed
  1. Re: Audi A6 (2006) European "Tourist Mode" - help needed
    Mar 2007
    Hi guys, this is exactly what I am trying to figure out.
    I have VCDS and have changed channel 23 to "1" to activate the "Tourist Mode".
    However, I am not sure it has worked; when I try "test" it is accepted and when I "Save" the lights do change and dip but do not become completely symmetric/flat. (I see the changes while parked in front of a wall in the dark, Xenons turned on while I enable "Tourist Mode"). VCDS also stores the fault code 02988 (as per below instructions by VCDS)
    Considering my VCDS accepts the code (for Tourist Mode") as "Test" and as "Save" does that necessarily mean my system is compatible for enabling "Tourist Mode"?
    The below guide refers to the Xenons need to be of a certain revision/age or newer, how are my lights compared to this? Sorry but not sure how to decode the revision numbers.
    How do your Xenon lights look like after enabling "Tourist Mode" please?
    I once did a mechanical "Tourist Mode" on a VW Golf mk 5 with xenons and then the headlights went completely flat.
    My car is from June 2005 (Audi A6 3.2 Quattro Avant).
    Here is the guide I've used from VCDS.
    Channel 010: Tourist Solution
    When driving in countries where driving is performed on the opposite side as in the native country the headlights must be changed over to avoid blinding the oncoming traffic. When active/enabled the Fault Code 02988 will be stored.
    0 = Disabled
    1 = Enabled
    Note: Only supported for 8P0-907-357-C @ 0020 or newer! Earlier versions require a mechanical Adjustment as described in the Factory Repair Manual.
    My car is LHD and will need to adjust the lights so I can register in the UK and pass MOT. Below is from VCDS (before I enable Tourist Mode).
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
    Component: AFS 1 H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000017
    Shop #: WSC 02335 785 00200
    VCID: 2648F4C6AEBD1B2C
    Part No: 4F0 941 329 B
    Component: AFS-Modul links H01 0010
    Component: AFS-Modul rechtsH01 0010
    No fault code found.
    These are actual pictures taken from my car. Camera in same position and car not moved at all from wall. Simply before and after enabling "Tourist Mode" while engine running throughout the operation.
  2. Re: Audi A6 (2006) European "Tourist Mode" - help needed
    Sep 2009
    Hamburg, Germany
    Looks to me like it worked - the beams are lowered. You should get a warning message on your dash after you make the switch, as confirmation. If you don't get this then the 'tourist mode' was not set.
    I rewrote my last post for clarity - it doesn't actually change the pattern itself; it lowers the beam so that the flip-up to illuminate the side of the road is now pointing lower and not into the eyes of oncoming traffic (when you're driving on the opposite side of the road to 'normal'). So it doesn't turn UK lights into European lights (nor vice versa), for example. The option is via "Xenon Range" in VCDS - the option makes some kind of change in the auto-levelling system of the xenon lights, so that the beams point lower. HTH.
    PS: If you're going to be driving this car permanently in the UK or Ireland I'd recommend swapping out the lights for RHD (UK/Ireland) traffic or you will keep getting the annoying warning about your lights being set 'wrong' all the time and you will also not be getting as much illumination on the road ahead and of verges/paths. Tourist mode is ok for a week or two on holiday but not as a permanent solution. UK xenon headlights from Ebay should not be toooo expensive.
  1. Advise needed please for bring my Merlin Purple Audi A4 to "sparkling" life!
    By JIGGY C in forum General Detailing/Cleaning Questions
    Last Post: 16-04-2009, 10:17 PM
  2. Golf Gt Tdi 110 "limp Mode" Problem
    By jamesknoedl in forum Golf MK4 - 1999 - 2004
    Last Post: 28-10-2008, 05:00 PM
  3. Audi A4 Avant - Panel Display - "In 1 "or "In 2"
    By infrance in forum Audi A4 - Archive Topics
    Last Post: 05-03-2007, 03:20 PM
  4. Amusing "tourist video guide" to Torquay
    By devonutopia in forum Chat - Completely Off Topic
    Last Post: 07-01-2007, 04:07 PM
