Thread: Intermittent Alarm 2002 Passat Estate!
Results 1 to 10 of 10
  1. Intermittent Alarm 2002 Passat Estate!
    Mar 2006
    Hi.
    I have an intermittent alarm problem on a 2002 TDi Sport Estate.
    Carpets OK. No Water in passenger footwell. Drainage holes in bulkead not blocked.
    Problem seems to occure after heavy rain. I believe there have been problems with a sensor/microswitch in the tailgate on Passat Estates!
    Has anyone had similar problems or any suggestions.
    Thanks Ted
  2. Passat alarms
    May 2006
    Hi, I bought my '01 130 TDI Sport Estate 4 months ago, when driving in heavy rain....... "glong"..... outside air temp drops to below freezing even though its at least +4c. Worst it ever been is -22c..... takes days to dry out & whilst its doing this the alarm is going off day & night. Are the outside air temp sensor & impact sensor somewhere where the water is not supposed to get?.There is an earlier thread regarding burnt out external air temp sensors, does anyone know where to look?
    Local VW *********** asked about the tail gate washers, its not unkown for the water pipe to the tailgate flush & brush to fail flooding the boot locked sensor with screen wash, mine has a pretty good jet so have discounted this. I too have no probs with wet carpets, dry CCD & clean pollen trap drains.
    Mar 2006
    Lanarkshire
    You could try the bonnet switch, as a collegue of mine had this problem on his 51 plate passat.
    Mar 2006
    Can someone tell me where the bonnet switch is please and maybe the
    VW Part Number?
    Thanks Ed
    Mar 2006
    Lanarkshire
    Ed,
    The bonnet switch is mounted in the bonnet lock mechanism as shown in the diagram
    The Part number is 3B0 953 236 D
    Hope this helps
    Mar 2006
    Great. Thanks for that will order one tomorrow. It's worth changing it just in case it's faulty.
    Ed
  1. Passat tdi estate alarm
    By Hope in forum Passat - Archive Topics
    Last Post: 19-07-2007, 01:15 PM
  2. VW Passat 2002 2litre Automatic Estate
    By Brian Shaw in forum Chat - Anything with wheels
    Last Post: 23-03-2007, 05:37 PM
  3. Bosch Aerotwin Wiper Blades - 2002 Passat Estate
    By jamoca in forum Archive posts
    Last Post: 09-01-2007, 04:13 PM
  4. 2002 Passat 2.0S Estate - which engine.
    By brendy in forum Passat - Archive Topics
    Last Post: 07-01-2007, 05:43 PM
  5. VAG Check for intermittent alarm
    By EddyStone in forum Passat - Archive Topics
    Last Post: 11-12-2006, 04:22 PM
