Thread: B5 Climatronic dead - more fuses?
  1. B5 Climatronic dead - more fuses?
    May 2008
    Hi All,
    I've got a 2004 130 TDi and the climatonic has suddenly died overnight after running perfectly. No display, no lighting, nothing. Almost seems as if an ISO connector or fuse has come adrift. I've checked the main fuse panel and all seem to ok there. The factory satnav/radio is in a double din above it and is all working as normal.
    Does anyone know if there's another in-line fuse tucked away anywhere please?
    Or any other likely remedies?
    Failing this, any ideas on how to remove the climatronic panel to get behind it to see if a connector has worked loose or parted? (It's really been wedged in tightly with a redundant Nokia 6310 car kit on a slide bracket between the climatronic panel and the main dash housing body so I don't want force anything).
    Any help will be really appreciated.
    gallic
  2. Re: B5 Climatronic dead - more fuses?
    Jan 2008
    Kinross Scotland
    It comes out very easily if I remember correctly. Carefully ease out the trim around the display (it is just clipped in.) you will see 4 torx heades screws. Remove them and the unit will be free to inspect the cable's.
    Do not over tighten the screws on replacement. Regards Richard
  3. Re: B5 Climatronic dead - more fuses?
    May 2008
    Many thanks, Richard.
    I'll give it a go this morning.
    With all the recent rain, it's getting a bit steamy - for all the wrong reasons!
    Quote Originally Posted by richard@thebrae View Post
  4. Re: B5 Climatronic dead - more fuses?
    Aug 2011
    Cedar
    Hello... I've read your post about your climatronic unit going blank; wondering if you figured the problem to be something easy to fix? I am having the same problem. Need help bad if you have a moment please!
    Thanks very very very very!
  1. Climatronic Dead
    By Ewan Bason in forum Golf MK4 - 1999 - 2004
    Last Post: 04-11-2019, 07:35 PM
  2. Fuses!
    By tone70 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2008, 01:47 AM
  3. Help with fuses.
    By Crockett in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 07:28 PM
  4. Dead radio - fuses??
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 11:15 AM
  5. fuses
    By leftys4js in forum Beetle 2000-
    Last Post: 27-01-2008, 12:28 AM
