Thread: climatronic flashing and no blower working
Results 1 to 10 of 18
  1. climatronic flashing and no blower working (now sorted)
    Jul 2011
    Durham
    Hi all just bought the car few days ago and realised the blower does not work at all i have replaced the motor as that was shattered to bits (plastic fins), I get a good power reading to the actual motor plug just wont spin UNLESS i put a direct earth to it but then only spins at full speed with no way of controlling it through the climatronic unit itself just after a bit of info as cant seem to find any posts or info on this particular problem usually all comes down to brushes which i know it isnt as it spins when earth is applied
    thanks to all who can help
    Well finally got it sorted turned out to be the actual climatronic unit itself had malfunctioned,Big thanks for everyones help and suggestions
    Last edited by cobology; 25-08-2011 at 02:12 PM. Reason: update to say issue is resolved
  2. Re: climatronic flashing and no blower working
    A fault code diagnosis will help but from what you say I suspect the fan power controller amp has failed. This is mounted in the air duct behind the clove bax. Worth checking it has not melted or the connector is burnt. J126 is the controller and it provides the earth for the motor speed control. Power is a direct feed to the motor form Fuse S225 30 Amp. Regards Peter
  3. Re: climatronic flashing and no blower working
    Jul 2011
    Durham
    Hi peter thanks for the response is that the part that has a red plastic cover and has a number of prongs when removed from the housing, is there any way of testing it ie. should there be any voltage in certain points that you know of? cheers buddy
  4. Re: climatronic flashing and no blower working
    It is retained by a single screw and has a three pin connector. Pin 3 is ground, pin 2 is output to the fan motor and pin one is a low level control voltage from the A/C control unit. Regards Peter
  5. Re: climatronic flashing and no blower working
    Jul 2011
    Durham
    Thats great m8 i will check over the connections and see what's what, if i get any further progress i will post back with any developments
  6. Re: climatronic flashing and no blower working
    Jul 2011
    Durham
    Ok i have replaced the resistor pack behind glovebox still no fan working at all, there is power to the fan plug all fuses are fine and have power to them display is still flashing when ignition is turned on. Fan works at full speed when a direct earth is attached, is there a relay which could be causing this problem really beggining to get annoying now especially with all the rain and misting up the windows
  7. Re: climatronic flashing and no blower working
    It is not a resistor pack but a Mosfet power amp. This controls the current with a signal from the A/C unit. It appears that this may be the problem. You need a diagnostic read to identify the problem. Find someone on here with Vagcom / VDCS in your area or a VAg independant. Regards Peter
  8. Re: climatronic flashing and no blower working
    Jul 2011
    Durham
    hi m8 thanks for the info where abouts is it located got a vagcom on way just waiting for delivery
    thanks sam
  9. Re: climatronic flashing and no blower working
    Forward of the steering column stick you head in the footwell and look up. Regards Peter
  10. Re: climatronic flashing and no blower working
    Jul 2011
    Durham
    LOL god i love the positions you need to get into!! i will av a look tommorow, p!ss!n down at the minute will update with any further evidence
    cheers sam
  1. Climatronic Display flashing
    By davejcb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2011, 09:39 PM
  2. Question Climatronic Flashing on startup
    By monkman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2009, 01:41 PM
  3. Question Climatronic flashing
    By MOUSE7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-09-2009, 08:35 PM
  4. climatronic display flashing?
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2009, 01:41 PM
  5. Climatronic Blower Fan
    By limawhiskey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2008, 09:49 PM
